#1747 | |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
#1748 |
Half a Bubble Off Plumb
That's about what I get, doing all of the above and with tires pumped to 44 PSI. Nearly all my driving's in town, though.
#1749 |
we achieve 40+ for both automatics with 35 > 36 P.S.I.. Just filled the sedan earlier and got 41.35 miles per gallon .
#1750 |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
Since I have owned my Yaris, including all the gas I've put in, my overall mpg is currently over 41. I just drive it. I shut off at long lights, it has been over 90mph, just auto crossed it last weekend. It has been to the fuel cut off. I get stuck in stop & go traffic. 42 psi frt, 35 rear. Synthetic oil, some stuff stripped out. 45mpg one time high on a tank full. Put 14" BBS wheels w/ 185/60-14 and it runs even better. I put photos on the forum.
doc 12k on it now in 13 months |
#1751 |
![]() ![]() Drives: 2008 yaris sedan Join Date: Jul 2010
There seems to be real difference what mpg people get in there Yaris,
I know drive style, Auto Vs manual and hybermile tricks account for some Of that, but could it be that some Yaris just simply gets better mpg than others regardless of Driver ,I am thinking there must be some kind of technical inconsistency in the engines or computers, there seems to be a fair amount people here with similar driving styles, but big difference in mpg. |
#1752 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I don't think the inconsistency theory about engines holds up.
I got 20-25% over EPA in my last ride which was a Suzuki XL-7. 24Mpg for a small/mid size SUV is not that bad. But with the Yaris, and starting with an EPA rating of 36, my commute average is 45. It took 16 months to get from 38 to 45, but now it is very consistent. Small tweaks (improved oil, filters, aero changes) by themselves might only get 1mgp improvement, but several of them combined with great driving will get very good mileage numbers. |
#1753 |
![]() Drives: 2010 2dr MT Liftback Join Date: May 2009
I own a 2008 hatchback and used to average 35 mpg with fast starts from lights and high speed on the interstates - all of a sudden when odometer turned over 70,000 typical mpg declined to 28. I have been using A/C this summer but also used A/C in the past. How can I check my emissions status, O2 sensor, etc. Anybody have any thoughts? Thank you for your kind attention.
#1754 |
The ScanGuage has ability to read engine error codes and it would be worth your time to borrow one for a week or more.
If you want to spend just a little money you can get a Toyota capable engine code reader or have a local shop plug one in a give you a printed report. I think an O2 sensor going bad at 70K is a little early. But emissions related devices are more likely than other items. However, I would also look toward your wheels. (really low tire pressure, stuck or dragging caliper, serious misalignment) 70K worth of New England potholes could most certainly have worn something out... |
#1755 |
![]() ![]() Drives: Mazda Protege5 Join Date: Jan 2007
O2 sensors can go at any time, it seems. But in this case there would be a CEL.
#1756 |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
I get the fuel consumption of 5.5 l/km, should be something around 43 mpg I do not really know how you are able to get 50 mpg
I have 1.33 1nr-fe engine and manual 6 speed trany ;) it helps a lot on the highway ;) nut still not able to get 50 :( |
#1757 | |
![]() ![]() Drives: '07 Yaris 5dr HB Join Date: Aug 2010
I currently have all tires at 40psi... |
#1758 | |
![]() ![]() Drives: Barcelona Red '09 Sedan Join Date: Jul 2010
Thing is anytime your foot is off (I mean off) the gas pedal you're getting better than 200 mpg (ac off right?) It adds up. Too bad our littl' Yaris doesn't have regen brakes say spinning up a little flywheel so we wouldn't have to feel so bad about using them... In time it will I suppose
#1759 | |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
Cheers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#1760 |
Machinist
Drives: Yaris sedan 2010 Join Date: Sep 2010
40psi, really? Damn
#1761 | |
![]() ![]() ![]() Drives: 2010 Yaris "5-door" Join Date: Mar 2009
#1762 |
I am trying everything possible but it is very hard in the city to push it below.
on the highway when I was doing 100 km/h I was able to push it on 4 l/100km ;) |
#1763 | |
"LibertyRides!"
Cheers!
#1764 |
"LibertyRides!"
YES! Would be nice if this was promoted and actively encouraged by American culture!
Cheers!
