Old 10-01-2010, 08:59 AM   #1
markitect
Drives: Yaris
Brake rotors (or drums) with rust(or anything else) on the braking surface, will cause vibration/oscillation while braking. It doesn't necessarily mean that your brakes are worn out. If you describe the symptom to your shop they should be able to fix it pretty easily.
If the wheels are oscillating it doesn't really matter what you do for stability, the tires simply won't make good contact with the ground.
markitect is offline   Reply With Quote
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 08:04 PM
heater control box issue DevilGirl DIY / Maintenance / Service 12 01-08-2010 03:45 PM
Weird issue during braking xtremesniper Canada 21 06-04-2009 11:00 AM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
