Old 10-01-2010, 11:09 AM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Derick,
I took out all my foam on the floor. I'm still figuring out what I need to do with that. .25 of a cube isn't much my friend. You can easily make that happen.
What was the midbass you were using again? If it's something the shop stocks, we can produce a pair of flushed rings for you.
Thoughts?
― Thomas Paine
Old 10-01-2010, 01:13 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Thumbs up
Derick, What was the midbass you were using again? If it's something the shop stocks, we can produce a pair of flushed rings for you.
Thoughts?
Thanks, here are the specs for "SB Acoustics SB17NRXC35-4"
LINK
Dimensions:
Flange diameter: 171mm
Cut out diameter: 144mm
Depth: 75mm
Flange thickness: 6.5mm
Screw mounting diameter: 159mm
Screw hole size: 4.3mm
I'm realizing how important is to have a good Mid-Bass up front for 40 Hz to 3.5 Hz Band, so I really want to try these with kick panels.
Thanks!
