Old 10-01-2010, 02:42 PM   #1
bizzlebaby
bizzlebaby's Avatar
Drives: 4 Dr 07 Sedan
Ok so I got it read at autozone ... 4 cylinder misfires. Only at 35000 miles. Tune up?
bizzlebaby is offline   Reply With Quote
Old 10-01-2010, 03:39 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
You shouldn't need a tune up with that little miles... However since your still under warranty and you know what the CEL is I'd head to the dealer.
EDIT: I just saw you have a 07 so I'm not sure what your situation is on your warranty. Mine ran out in less than 2 years as I hit 36k miles.
Old 10-08-2010, 07:40 PM   #3
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
did you mean all 4cyls misfire or #4cyl misfire?
if all 4 misfire might be ecm related
if #4cyl misfire could be faulty coil
OTA'sTOY is offline   Reply With Quote
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 08:54 PM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 12:30 AM
