![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Hard turn wobble
Hi, When ever I make a hard left or right turn from a stop, the car has a harsh wobble shudder that seems to be getting worse over the last few years. I have the TRD sway bar but thats the only suspension mod on the car. Any thoughts as to how to eliminate or reduce this annoyance?
ekodrvr
Drives: 2002 white subaru impreza wrx Join Date: Feb 2009
your car is manual trans, or auto?
if manual, sounds like clutch shudder... exacerbated by steering input... when i had my echo, it happened ocassionally... it auto, i have no suggestion... but will need more info... year, trans, miles, etc.
if you want to see my plans for this car, check out here... http://www.cardomain.com/ride/3154316 i like this smiley...
My car has automatic. The shudder is in the entire car. I believe it is suspension related. Feels like it.
ekodrvr
well, i am honestly unsure... i would need to look at car in person to go farther... where are you in the country? however, it might behoove you to take this in to the dealer and ask them/ show them what you are talking about...
prop215.
Drives: Toyota Yaris LB Join Date: Sep 2010
it could be that sides A arm its could be loose?
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
a bad CV Half Shaft?
Learn to Relax
It's normal.
prop215.
^c'mon you mean to tell me when you turn hard your yaris wobbles cause i know for damn sure when i do it does not wobble
I took it to the dealership and drove it with the service manager sitting in the passenger seat and could not produce the wobble. I went ahead and had them inspect the car and alignment. Everything was normal. The wobble will occur again like the occasional huge rattle deep beneath the dash board. Imperfections I can live with in an over all splendid entry level ultra low emission vehicle.
#10 | |
ekodrvr
then you can take all that information in to the dealer, and then they can have a much better chance at a) recreating the issue, and b)determining the exact problem
| Dashboard lights turn off when I turn use headlights | patate15 | DIY / Maintenance / Service | 7 | 07-05-2020 04:05 AM |
| Sound when making a left turn (a water flow sound) | jimmydie | DIY / Maintenance / Service | 9 | 06-20-2013 06:35 PM |
| Are rear red turn signals planned for Yaris as well ? | 77W | General Yaris / Vitz Discussion | 38 | 02-22-2010 07:41 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-29-2009 12:53 AM |
