Old 10-04-2010, 09:15 AM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Low Tire Pressure Sensor
This morning was the first really cold morning since I got my Yaris in June - it was 37 degrees here. I started out for work and the low tire pressure indicator came on, I drove to the nearest air thing, put my 75 cents in, and couldn't get any of the caps off - I guess whoever installed the factory tires didn't know their own strength.
Finally I got a guy to loosen all the caps for me, but none of the tires are really that low - 31 or 32 lbs. in each of them. Is this something I have to put up with all winter - that light on the dashboard is driving me crazy. (I saw the thread on un-doing the sensor but I'm not into all that.)
If all it takes is 3 lbs. to make it come on, that's a real pain in the butt. I think this sensor is the stupidest thing - cars have been around forever and we got along just fine without these sensors.
DebbyM46227 is offline   Reply With Quote
Old 10-04-2010, 09:28 AM   #2
sleey0
Drives: 2008 Yaris LB
You can disable it by tapping 2 wires together.
Find the "Disable TPMS thread:
i agree this is stupid. It does't even tell you what wheel. Would it have been too hard to show different color light for each wheel or even just have an LED on each corner of the light to show which tire?
I disabled mine and haven't looked back!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-04-2010, 09:52 AM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
To have it on the car at all, from what I understand is government mandated. Fuel waste and safety issues from running low tires. So Toyota or any other mfg isnt going to do the which tire is low on a normal basis. Unless its a higher end model maybe or incorporated into some other customer paid option package. Right now its on our cars because they have to.....Right now the computer gets a signal from a TPS, period. To tell which one it is would require differentiating a distinctly different signal from each one versus a generic signal as it is now. extra costs which you and I would have to pay for.
Old 10-04-2010, 10:20 AM   #4
DebbyM46227
you are paying for the idiots who got killed because they didn't check their tires regularly, so the nanny government is forcing every car to have these sensors.
btw its normal for the sensor to come on when its colder since the air pressure inside your tire gets a bit lower when its cold and will go back up when the tires warm up
Idiots! You've got that right! Now I'm wondering if I really do have a low tire - since after my 14 mile drive to work it was still on. I'll have to keep an eye on it, maybe the light will be off the next time I start my car up.
Old 10-04-2010, 10:41 AM   #5
You might have a bad sensor, as the light should go out as soon as pressure is restored.
Old 10-04-2010, 11:31 AM   #6
DebbyM46227
Thanks, CT :)
Old 10-04-2010, 12:12 PM   #7
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
My car doesn't have the TPS option..not that I'm complaining. They must have only had it on the models for a few years here in Canada. Mine's a 2010.
But yeah, all I usually do is take a quick peek at the tires before I get in the car. My own eyes are probably more accurate than a TPS.
Old 10-04-2010, 06:13 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Amen to that. My parents had to have the sensor in there Nissan Murano changed because it went nuts. I think it was reporting half of what is was for awhile, then just decided random numbers were cool.
Colin Chapman disciple
Old 10-04-2010, 08:22 PM   #9
Palmer812
Drives: 2010 Meteorite Metallic LB
I bypassed mine at 600 miles when I got new wheels. I just check my tires every week or so.
Palmer812 is offline   Reply With Quote
Old 10-04-2010, 08:29 PM   #10
sickpuppy1
My wifes 2004 Highlander started having the light come on constantly even though we went thru the reset process. Found out how to reset them. hers has a reset button under the dash. If you reset it and it thinks its too low from factory setting it comes back on. Found you let air out of all tires to like 28psi and hit reset button,shut it off, then reset it again and it will accept new setting as default. Never had it come back on again after a full year now!
Old 10-06-2010, 11:24 PM   #11
CrazedEpidemic
Drives: 2008 Toyota Yaris Sedan
I actually think the sensor is quite helpful. In my experience it has only come on when my tires were below 25PSI because of a nail being in the tire I didn't even know was in there. It has helped me numerous times from driving off with very low tire pressure.
CrazedEpidemic is offline   Reply With Quote
Old 10-11-2010, 04:26 PM   #12
markitect
Drives: Yaris
The only time mine have come on, all the tires were above 32 PSI, and when I turned the car back on after checking it went away. The dealer 'made a note'
markitect is offline   Reply With Quote
Old 10-18-2010, 10:02 AM   #13
1stToyota
1stToyota's Avatar
+1
I'm sure this stupid option saved my wheel and tire, and maybe even more if I would have had a blow out on my right front tire. I thought I dodged the board in the road, but I didn't quite make it. Didn't think anything about it, but about a mile later the light came on because I picked up a nail. I live 25 miles from work and probably would have ruined the wheel and tire if I would have kept driving. Luckily I was able to safely pull into an abandoned Wal-Mart parking lot and put the spare on.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-07-2010, 07:54 AM   #14
TRDMarty
What does this sensor look like?????
Anybody have a pic of one?????
When I put my TRD 18's on, they didn't have the sensors.
I've been thinking of buying a set from Toyota.
Anyone?? Anyone??
Old 10-07-2010, 07:58 AM   #15
DebbyM46227
http://www.toyotatpms.com/
Old 10-07-2010, 03:17 PM   #16
TRDMarty
Thanks Debby
I'll have to stop by my local dealer to see how much they cost$$$$
Old 10-09-2010, 12:18 PM   #17
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
if the light is blinking all the time you have a faulty sensor/missing sensor. If the light is solid you have low air pressure, the sensors are programmed to alert around a loss of 6 or more psi.
To debby: odds are whoever checked your tires for you was using a 'stick' air gauge which can be grossly inaccurate (as you stated it was only off a few psi). either a digital or dial gauge will be much more accurate. you can pick one up at auto stores or automotive departments for like $5-10 bucks.
Old 10-10-2010, 11:22 AM   #18
DebbyM46227
Thanks, Shroomster....it was a stick air gauge - I'll have to get one of those you are talking about - digital sounds good! I've always had the stick kind and didn't know there were other types.
I aired up all my tires and the low pressure light went off, so I guess they were all low. Or at least one of them since I couldn't tell which it was. I looked at the dashboard each time I aired one up, and it didn't go off until I did the last tire.
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
