#1 | |
Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
TPMS Reset
Press and hold in the TPMS Reset button and then turn the key to the engine run position, wait a few seconds and the light should go out. If ALL the wheels show correct pressure, an it still illuminates the (!) driving a short distance usually resets in about 2 blocks of travel. (It's a pain eh?) |
#2 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
![]() Drives: 2009 Yaris 3 door hatchback Join Date: Oct 2009
TPMS reset
On a 2009 3-door, where's the reset switch?
It doesn't have a physical switch. It can only be manually reset using the Toyota Techstream tool:
3. CLEAR DTC After repairing the malfunctions, clear the DTCs. (a) Turn the ignition switch off. (b) Connect a Techstream to the DLC3. (c) Turn the ignition switch to ON and the tester on. (d) Enter the following menus: Chassis / Tire Pressure Monitor / Trouble Codes / (e) Clear the DTCs following the prompts on the tester screen |
#5 | |
Thanks. I wondered why I couldn't find it. Will a Power-on-Reset (battery disconnect) work?
#7 | |
With a little jumper wire, you can get the system to flash the light to tell you exactly why it's not happy: http://www.yarisworld.com/forums/sho...8&postcount=11 |
| The "let's brainstorm how to make a piggyback work" thread | eTiMaGo | Forced Induction Forum | 83 | 08-17-2011 03:54 PM |
| Single Tire Replacement - Using Pressure Sensor? | 1stOne | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-13-2010 10:25 AM |
| Tire pressure sensors | ztlonewolf | DIY / Maintenance / Service | 14 | 04-25-2009 05:19 PM |
| Higher Tire Pressure | captainm27 | General Yaris / Vitz Discussion | 46 | 01-27-2009 10:17 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
