Old 02-26-2013, 01:34 AM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Damages:Cracked windshield, 2 flat tires, and just this year my brother reversed into the side of it. Apart from that nothing has gone wrong
Old 03-02-2013, 12:28 AM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Car was a short term lease return when we bought it - literally like new. Had a couple of flat tires early on from picking up nails - fixed on warranty. Absolutely nothing else has ever gone wrong - not so much as a burned out bulb. (The car is pretty gently used - only 75000 km.)
Sir A.Y. Atoyot is offline   Reply With Quote
Old 09-20-2012, 08:51 AM   #3
hatchbackkid82
Drives: .
As far as reliability and cost of ownership goes you can't go wrong with a Yaris. I'm on my second Yaris. The first one I wrecked, that one was an 07 LB 5 speed. Never had an issues, never left me stuck anywhere and always started, even in the coldest of winters here in MD. I only had to repalce the battery. Mileage on it was about 78K when I wrecked.
I have an 10 Sedan AT, no issues yet. Hopefully this one is as reliable as my LB.
Stya on top of regualr oil changes and you should be good, theses cars are pretty much gas and go. This is probably one of the most reliable cars I've had.
Old 10-24-2012, 01:04 AM   #4
birdman
Drives: '08 Blazing Blue Yaris LB
I have had the car for 4 years, 45k miles and I have no plans on selling it. The battery needed replacement but that was due to a faulty after market mileage guage. The right front power window has developed a weird sound but works fine fingers crossed. Years ago I had a few Civic wagons that were very reliable and I'm hoping in another 4 years i'll be saying the same about this Yaris.
birdman is offline   Reply With Quote
Old 01-07-2013, 02:07 PM   #5
Solid T D
Drives: 08 3dr Yaris S"arah"
2008 Hatch "S" @ 37000 since 12/08. I've been REALLY hard on her, but she's a soldier and won't quit. I've only had to deal with maintenance and the occasional modding.
Only issues that I've had:
Radio wouldn't shut off after I shut the car off. (I would leave my power inverter in the cigarette plug; I guess it would feed,reminiscent, power to the radio. (no inverter, always shuts off)
Intermittent issue:
The car doesn't seem to want to start, when I turn the key. Starter turns, but the engine doesn't turn over. She starts up after the initial scare, so I haven't been able to replicate it, so it's seems random. (hot, cold temp; cold, warm starts. I can't figure out whats wrong with her. Coils? I dun kno)
Solid T D is offline   Reply With Quote
Old 01-08-2013, 01:29 AM   #6
birdman
I think if you do your oil changes regularly and make sure it is serviced at the recommended intervals then your chances for the car being very reliable are better than most other cars out there.
Old 01-08-2013, 02:10 AM   #7
mr_miles
Drives: 2013 Yaris
Mine has 6500 miles on it and still running strong! lol. someday I hope to see it break 100k.
Old 01-08-2013, 11:24 PM   #8
nookandcrannycar
Wow. If the Yaris is your only car, you have more willpower re staying away from driving than I could ever muster...unless the entire U.S. adopts a miles driven based tax.
Old 02-26-2013, 12:52 AM   #9
nookandcrannycar
I was just clicking through the slideshow at the top of the msn.com homepage
and one of the 8 tiles/subjects really caught my eye, namely "Will your car break the 300,000 mile barrier". I clicked to the linked slideshow and then through the slideshow. They commented on 12 cars. One of them was the Yaris, and the blurb was one of the most complimentary blurbs I've read re the Yaris. The URL for the Yaris tile in this slideshow is -- http://editorial.autos.msn.com/can-t...d=autos_3339#8
Old 02-26-2013, 01:08 AM   #10
nookandcrannycar
P.S. - I clicked on the URL link I created. It didn't work. Then I noticed that I had the Yaris tile from the slideshow open in another window. I then closed that window. I then tried the link again and it worked! So...if it doesn't work at first...try again later.
Old 03-05-2013, 03:41 PM   #11
ThomasOkken
Drives: 2007 Yaris 2D LB 5sp man
I have a 2007 2-door liftback, bought new, currently at 102,500 miles. The first set of tires lasted 75,000 miles. I have had two issues with it: the voltage sensor failed once and was replaced (found out later that it probably only needed to be cleaned and re-sealed), and had glazed front brake rotors (which usually means operator error but I can't imagine where or when I would have ever overheated the brakes, driving in NJ and NYC). Also, after the rotor replacement there was slight squeaking and vibration at certain speeds.
In all, the car is near perfect, but I am thinking of getting it serviced elsewhere!
I'm getting about 38 mpg, which is better than the EPA rating of 32 mpg, but not as good as the 40+ I got out of the 2000 Civic DX I drove before. Then again, the Yaris' engine seems to have a much wider power band (same HP), and combined with the great suspension and steering, it encourages a fuel-inefficient driving style. :-)
ThomasOkken is offline   Reply With Quote
Old 03-05-2013, 08:24 PM   #12
ThomasOkken
Oh, forgot one issue: seized caliper pins in the front right brake and resulting rotor damage. So that's two brake issues (one of which presumably my fault), three if you count the squeak/vibration issue, though that one is not the car's fault but the dealer's.
Old 03-06-2013, 02:40 AM   #13
jangvt
Drives: 2012 yaris
i have 2012 yaris se with 30k miles so far i kinda want to add a turbo to it for more power
jangvt is offline   Reply With Quote
Old 12-05-2017, 11:13 AM   #14
09cptn
Drives: 2010 Yaris Sedan
We have a 2010 sedan with nearly 123,000 miles. So far, all I have replaced are fluids, one accessory drive belt, spark plugs, and 1 battery. Very trouble-free car. We have road-tripped it from VA to NY, VA to KY, VA to CA when we moved, and Los Angeles to Seattle. I am sure it has 100K+ more miles in it, but I'm not sure how many we will see. I really want a convertible.
The Yaris: 2010 Yaris base model. 50% tint up front and 35% in the rear, Konig Lace wheels with homemade Toyota center caps on Yoko S.drives, Curt hitch.
Offroad: 2004 Jeep Wrangler lifted on 33's
09cptn is offline   Reply With Quote
Old 12-06-2017, 01:28 AM   #15
komichal
Bought mine 2007 Yaris 2SZFE five years back with 37,000 miles.
I am now on 87,000 miles.
Over those five years I had to:
- change spark plugs twice (once after I bought it and second time just recently. I did not have to but I wanted to)
- change bulbs twice
- replace a few malfunctioning LED in the dashboard
- change brake fluid twice
- change coolant once
- change water pump once
- buy tires (winter, summer) several times
- change gearbox oil
- change engine oil + filter numerous times
- change front brake pads and rotors once
- change battery once
- fix blocked rear right door lock
- replace ABS sensor for rear right wheel
- clean MAF sensor once (engine was coughing when idling)
- replace air filter a few times (living in a dusty area near stone quarry)
- fix rear window heating
- change wiper blades several times
- change front wheel bearings
- every year AC system cleaning and adding a few tens of AC coolant
And what I see ahead:
- my exhaust (still original) started to rattle in low rpm, Seems like internal part is no longer in its place. Will replace it during spring. Hopefully it will last till spring.
- the testbed shows my rear shocks are almost gone, so are the front ones. Will change them once the winter is gone if there is some spare cash.
- my clutch is very stiff. Not going to do anything about it as long as it does not slip.
I do not think that the Yaris is nearly-maintenance-free car.
Old 12-06-2017, 05:57 PM   #16
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
I have a 2006 Yaris. Owned it for 15 months and drove about 16.000 miles
Regular maintenance:
- two oil changes
- oil filter
- air filter change
- brake fluid change
- coolant change
Faulty Parts:
- leaking waterpump
- pulley bearing
- loose windows
I feel bad for this car because I believe my racing and off-roading made it fall apart.
The waterpump was leaking and the screws that hold the windows tight came loose,
probably because of extensive vibration (off-roading). I guess that's what I get.
Oh yeah the car needs to pass TÜV Inspection this Friday, so wish my luck haha.
DiCaprio is offline   Reply With Quote
Old 12-08-2017, 10:59 AM   #17
DiCaprio
Just a Gaijin
DiCaprio's Avatar
My Yaris passed the inspection. They only had to change the rear brake pads.
(Every 1.3l french build car has rear discs instead of drums, as far as i'm concerned)
I'm just curious as to why the back brake pads worn out quicker than the front ones.
Old 12-08-2017, 08:04 PM   #18
dogsridewith
Drives: 2007 2-door hatchback
brake pads rust corrosion dirt front versus rear
Because the rear rotors are more contaminated/corroded? Like everything else at the rear of the car...from spray off the front tires. Notice how much thicker the crud layer on the backside of the rims is on the rear vs. the front? (Can see this on the outside of rims too.)
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
