Old 10-04-2010, 02:03 PM   #1
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
How reliable is the Yaris?
Hi all! I just purchased a used 2007 Yaris 4 door hatchback about a month ago. It has 67,500Km (41,942 miles) and so far I'm loving it!
As a first time Toyota owner, I just want to get some feedback on reliability.
I keep hearing how Toyotas are very reliable, but are there any significant problems with the Yaris that I should be concerned about?
If anyone has ever had mechanical or other issues please post.
Thanks!
Eatoman is offline   Reply With Quote
Old 10-04-2010, 03:06 PM   #2
swidd
Drives: Yaris HB
77,000 miles, I have only done oil changes, filter changes, wiper blade changes, transmission fluid change, replaced the tires once.
Old 10-04-2010, 03:49 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
We have a member that has over 350,000 miles on his I believe and had no major issues up until just a little while ago. Not that he has a major issue, just a rather odd one. And yes, I did mean 350k. He was using it for his job which required hours upon hours on the road. I am at a loss for his avatar however if you even do a search in the forum for 100,000 oe 200,000 you should find his threads.
Old 10-04-2010, 03:50 PM   #4
detroiter
detroiter's Avatar
I want to say that member topped 400,000 miles now. I might be wrong but I'm pretty sure. Crazy stuff!
Old 10-04-2010, 05:44 PM   #5
Eatoman
Eatoman's Avatar
Yeah I know which member you're talking about, but I can't remember the name either...I saw his video on youtube...quite impressive! What about rust problems?
We have some pretty harsh winters here in Canada...and all the road salt really takes a toll on our cars. So rust is really one of the things I'm concerned about...
Old 10-04-2010, 05:46 PM   #6
Eatoman
Eatoman's Avatar
Dang! That's impressive swidd! I'm starting to feel like I really made the right choice by buying a Yaris. :)
Old 10-04-2010, 06:08 PM   #7
PaddyMac
PaddyMac's Avatar
Drives: 09 Yaris
55k with no problems
I have 55k on my 09 four door with no problems. I change my oil at every 5k and i put new tires on it at 40k.
PaddyMac is offline   Reply With Quote
Old 10-04-2010, 06:19 PM   #8
kimona
kimona's Avatar
Drives: 2014 White VITZ
Approaching 50K miles and have replaced the battery and tyres... and the hatch lift supports (under warranty).
Old 10-04-2010, 08:07 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i haven't even needed to replace the original battery yet. Only thing I've needed to do was replace the tires, and i'm almost at 60k miles.
I did do the 10k services for a while when I had the extra cash, but that was simply because i could easily afford it.
Colin Chapman disciple
Old 10-04-2010, 08:38 PM   #10
SimTronik
Machinist
Drives: Yaris sedan 2010
I own a yaris since 2009, only had to replace tires. I do lots and lots of road.
SimTronik is offline   Reply With Quote
Old 10-08-2010, 06:15 PM   #11
bankrobber
Drives: 2007 Yaris Hatchback
I have a 2007 HB and I have replaced battery, 2 tires, and the bulb for the fan speed control. Not bad for 97k
bankrobber is offline   Reply With Quote
Old 10-08-2010, 07:20 PM   #12
sleey0
Drives: 2008 Yaris LB
Just went to.ziebart.for.undercoating. very good stuff. Its.black and.tacky. NOT.rubber. do not.use.rubber.undercoat.
One.crack.in.the rubber and sal water gets trapped in there and it will highly start corrosion. And u wont know whefe itt is until your frame.getss.rusted oit.
Also.check out waxoyl. Very good stiff!
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-08-2010, 11:50 PM   #13
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
79k miles, oil changes and a little stp gas treatment.
Club SHIFT
Old 10-09-2010, 12:16 AM   #14
PhillyG
Drives: 2009 Yaris
i will tell you what i like about the yaris. i am on my second one. i had a 2007 and i was on a road tip on christmas eve 2007. well actually it was bout 2 am christmas morning. i was cruising about 75 mph on an interstate. when a deer jumped out of the ditch in front of me. There was absolutely no way i could have avoided it. i didn't even have time to hit the brakes. My fiance and dog were asleep in the passenger seat. both airbags went off.. and after spinning/sliding around multiple times. we stopped. noone was hurt. noone even got a bruise. the car was totaled but all the crumple zones works perfectly. this car a the usual rattles and squeaks of a cheap sub compact. but with toyota quality there are rarely any major issues. i love the gas mileage i get. and because it saved my family and me. i got a 2009 when cash for clunkers came about. i love this car for its affordability, reliability, and quality. when it comes down to it. its one of the best, cheapest cars on the road.
edit: the only casualty of that wreck was my cell phone.. the screen got cracked.. but the presents in the back never even got wrinkled wrapping!
PhillyG is offline   Reply With Quote
Old 10-09-2010, 01:01 AM   #15
krolos
Drives: 2008 yaris sedan
My yaris just turned 36k miles this morning and no problems.
krolos is offline   Reply With Quote
Old 10-09-2010, 01:17 AM   #16
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Used '09 I've had since August 3, 2010. About 33,000 miles and smooth sailing **knock wood 3 times**
chrisj is offline   Reply With Quote
Old 10-09-2010, 09:35 AM   #17
zachryboles
Chunk love Yarii
Drives: 2008 Silver 3DR Yaris Liftback
im pushing 48k miles on my 08 hatchback. i have no problems other than my short shifter kit squeaking once in a while. Im expecting to run this thing into the ground..... im estimating using it till 120k miles then ill get something else. A quick side note, i also crashed a sedan at 75 when i t-bonned a lady that ran a stopsign at an interstate thruway. I had cracked ribs but that was because ive cracked them before. My passenger was a ok and technically i was too so i would recommend this vehicle for new drivers for its safety.
Yarii's falice enhancement list:
30% Tint W/ 15% Rear Tint, Tanabe DF210 Springs,Tanabe Concept-G Exhaust,Injen CAI,Piggies SSK
Recent Kills:
06 Vette, 08 Cobalt SS, ?? Civic Del Sol, 10 Audi TT
zachryboles is offline   Reply With Quote
Old 10-09-2010, 11:16 AM   #18
bigdoglover
Drives: 2007 red lb
07 liftback auto trans with about 33,500 no problems yet-bought her new. only have needed to do oil changes, tire rotations and just replaced the wiper blades. currently getting appr. 39 mpg in chicago suburban driving, no expresssway driving.
bigdoglover is offline   Reply With Quote
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 12:03 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
