![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Well, oif course I aint't pulling that small bastard to just pu the kit on.
I am getting CP 75mm pistons and Crower rods.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
Bathroom + Laptop = <3
Still think it would be easier just to remove the head alone and not risk things/fluids too. Also make sure you get some head studs. You cannot reuse stock head studs, most of them now a days are all stretch bolts and thats a no no on reuseability. Same with flywheel bolts.
Where can I get 1NZFE head studs?
Garm got them custom, but Toyota has them for sure i bet at like $5 per stud. Also another way to lower your compression to push more boost is to get a thicker head gasket. I don't know how much your pistons will lower them, but the headgasket is good for another .5 of a drop
#5 | |
Where exactly did the 30% come from?
#6 | ||
Oh yes and HEET is a great substitute if you can not find methanol in bulk quantities, also most washer fluids will list methanol content if you can do some calculation on what temperatures they work in. Roughly a -20* solution is 25-30% methanol, but living in a state where it rarely freezes.... the closest I ever found local to me was +20* washer mix Quote:
My 30% by volume (not weight) came from my own diagnostics. I'm not saying I'm a "genius" by any means but it ran quicker from 25 to 75 mph in 5th gear when the mix was between 2/3 to 3/4 water to 1/3 - 1/4 methanol. Of course if you live anywhere outside of my neighborhood (humidity, elevation... blah blah variables), this may not be helpful to you. However, I was sharing what worked for me... sorry for the intrusion....
#7 | |
#8 | |
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
Your engine builder is full of shit, will take a few hours to pull the motor correctly. And if your gonna do some piston changes that change compression and or CC you may have some trouble with that piggy back ECU.
Your engine builder is working in dream land and your in for a wake-up call on this whole thing. My self and Garm got more time under the hood of these cars than your engine builder probably has in his whole career. Your whole situation is unrealistic and there is a world of issues headed your way. A few hours to put new pistons and rods in. ![]() Not if you have file fit rings and you want to check everything. Not to mention you need to knoch the block for the Crower rods to clear. Also there is no ARP head stud kit for this car. You have to go custom like me and Garm. And untill you go big like him and I you don't even warrent them. Good Luck with this disaster XBG Last edited by xbgod; 10-07-2010 at 04:44 AM. |
#10 | |
#11 | |
Yaris = Electronic power assisted steering
Kinda surprised no one has said this yet but uh...
How about you just put the turbo in and deal with pistons/rods/meth/everything else later. It's like you're trying to do brain surgery, file your taxes, build a time machine, and create a dog/cat fusion all at once. What's the rush? |
Gonna be pretty hard to trouble shoot...
But that's probably exactly what the installers want to have happen.
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
I'm guessing he doesn't want to disassemble the turbo once it's on in order to get the new pistons in and sleeve the block if he wants?
And some new info gained by a trusted member.
Pistons and rods may be a project down the road now depending on my funds standpoint here in the next month or two, So no more bashing/talking/whatever about the rods/pistons and engine pull plz.
Back to my project.
Should I get the 1ZZ injectors? Or go bigger, like tC? Performace/sftermarket ones? Any suggestions......Thanks
I would have went the windshield wiper fluid route for the meth, but because I am in hawaii, they don't sell the windshield washer fluid that could work.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Turbo Project Yaris TS 1.8L | CASTREX | Yaris TS Talk | 40 | 08-21-2009 10:24 AM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Turbo Kit - trade for stock parts! | crankyelbow | Items for Sale by private party | 62 | 02-03-2009 12:30 PM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
