Old 10-05-2010, 12:01 AM   #1
bhola
Drives: 2007 Yaris
You can pick up a little squeeze tube of powdered graphite at an auto parts or home center. You simply stick the tip into the lock, squeeze it a couple times, and then run the key in and out a bunch of times to distribute it.
This worked!! Thanks a lot for quick response and your help.
bhola is offline   Reply With Quote
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
