Old 10-06-2010, 08:44 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i got a question that deals with the lug studs. is the thread pattern the same as honda's thread pattern? i got a set of rims but the diameter of the hole doesnt quite fit my 21mm socket which is a 12 point skinny socket. but they do work on my crx which uses 19mm socket. is the thread the same as the honda civic/crx 4x100 studs?
i could easily find out this weekend but im at work and figure this would be a good information if anyone else had this question.
Old 10-06-2010, 08:56 AM   #2
The CRX also uses M12x1.25 lug nuts, so the studs are the same, but the outside of a lug nut can be any size. For example, the stock lug nuts that came with my Yaris steelies use a 21mm socket, as do the lug nuts that came with my Toyota TTE alloy rims, but the lug nuts that I need to use with the mini cooper rims (that I run as my winter rims) use a 19 mm socket.
What size allen wrench for auto transmission drain bolt? detroiter DIY / Maintenance / Service 6 03-30-2019 02:55 PM
Bolt Pattern Size and Offset for the Stock Wheels fmicle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-12-2009 03:35 PM
head bolt socket. What size? beemer dave DIY / Maintenance / Service 3 06-02-2009 04:15 PM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 07:03 AM
