Old 10-07-2010, 11:43 AM   #1
chilly79
Drives: 09, 3dr, LB, Carmine Red
I was going to take it apart tonight to see if I could figure out what I did to the speedo. I thought I got it on there right though.
The LCD was my issue. It seems to be connected to the PCB directly. It looks like I could lift the LCD up and slide the it through the white housing when I pull off the PCB. I was not sure though and thought that this might break it.
So are you saying that I need to remove the odo LCD from the front after I pull off the overlay?
I hope this works I would really like to be able to fix this instead of getting a new one. I saw all the threads about mileage issues after changing a cluster that I would rather avoid.
chilly79 is offline   Reply With Quote
Old 10-07-2010, 11:46 AM   #2
Yes - The LCD pulls out from the front once it overlay is removed.
Old 10-07-2010, 11:59 AM   #3
chilly79
Thanks I will try this when I get home.
