Old 10-07-2010, 06:58 PM   #1
.Kevin.
I ain't even mad
.Kevin.'s Avatar
Originally Posted by RedRide View Post
I can't help with the center caps as there are many that wiil either fit of not.
However, I can definately recomend trim rings.
Most will recomnend ABS chrome rings and I agree.
You need a ring with depth olf 1 3/4 inches.
These are the exact same ones (same vendor, ships world wide) I got.
They are top quality and look great.
http://cgi.ebay.com/ebaymotors/15-ST...item439d911275
Here's a pic of them on my Yaris.
http://www.yarisworld.com/forums/sho...ght=trim+rings
Awesome thanks, how do I buy those rings, and how do I put them on o,o do I just select 1 in the amount for a set of four or are they each 39.99.
And thanks yoru hubs are nice ! Note I drive a sedan youre sure theyll fit :o
Old 10-07-2010, 09:25 PM   #2
RedRide
RedRide's Avatar
They are $39.99 for a set of four. Just select 1(set).
The 15" steelies for the sedan and HB are exactly the same.
You install and remove the trim rings just like a hubcap.
EDIT....
I originally mistakenly gave you the address of the auction for the stainless steel rings instead of the ABS chrome rings which I definately recomend.
Bellow is the ABS rings.
They are also $39.99 but, they are shipped for free so, they are cheaper
http://cgi.ebay.com/ebaymotors/15-CH...item43a1db3694
My trim rings and center caps..... RedRide Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-05-2017 06:42 AM
TOYOTA center caps and Trim Rings for sale. coffiend Items for Sale by private party 10 05-11-2010 06:29 PM
custom center caps? or vitz center caps BrazdonW Cosmetic Modifications (Exterior/Interior) 2 09-06-2009 11:21 PM
Toyota center caps regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-14-2009 12:43 PM
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 07:09 PM
