Old 10-10-2010, 10:08 AM   #1
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Walt,
According to Toyota the WS ATF doesn't need to be changed. I personally am going to service mine regularly because I plan on keeping it for a long time. If you plan on keeping yours beyond 100k or I would service it. Toyota is the only official source of WS but other fluids are recommended for it including Valvoline Max Life, Amsoil, Redline, and Amalie.
Why?,
To address your question transmission oil should really only get "dirty" from wear particles and oxidation of the fluid itself (although other sources of dirt or water are possible). This would be most detrimental in that it could cause accelerated wear, but in severe cases oxidation and the subsequent thickening of the fluid could affect FE (though probably very little). I would worry mostly about the increased wear issue, however. If I owned a manual Yaris I would change the gear oil in the Yaris every 30k with a high quality fluid.
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Old 10-10-2010, 10:46 AM   #2
c-dub
Drives: 2008 yaris
what fluid would you use? would you go synthetic?
c-dub is offline   Reply With Quote
Old 10-12-2010, 10:39 PM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
Castrol Import fluid would work fine... if you want to go synthetic just about any of them will work. Just look on the back of the bottle and make sure it says it meets Toyota type fluid requirements.
I have changed the fluid in my; 06 Scion xB, 08 Yaris and 01 Rav4 with the Castrol import and a new filter and gasket with zero problems
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
BIG driving lights.... how? jonismyname Cosmetic Modifications (Exterior/Interior) 22 09-30-2010 07:54 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
Re-did lights, fixed scratch, RR floor mats! lots-o-pics dg4rez Photo-Video-Media Gallery 15 04-21-2009 01:45 AM
