Old 10-10-2010, 11:22 AM   #1
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Thanks, Shroomster....it was a stick air gauge - I'll have to get one of those you are talking about - digital sounds good! I've always had the stick kind and didn't know there were other types.
I aired up all my tires and the low pressure light went off, so I guess they were all low. Or at least one of them since I couldn't tell which it was. I looked at the dashboard each time I aired one up, and it didn't go off until I did the last tire.
DebbyM46227 is offline   Reply With Quote
Old 10-10-2010, 12:35 PM   #2
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
TPMS Reset
It takes a little while for the TPMS to recognize that the air pressure is back to acceptable levels. Sometimes you will actually have to MOVE the car in order to initialize the reset. I have also had to revert to the button reset method on 2 occasions, as it would not reset by itself. The button method:
Press and hold in the TPMS Reset button and then turn the key to the engine run position, wait a few seconds and the light should go out. If ALL the wheels show correct pressure, an it still illuminates the (!) driving a short distance usually resets in about 2 blocks of travel. (It's a pain eh?)
bobolinko is offline   Reply With Quote
Old 10-11-2010, 12:25 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Unless your model year scion has this, toyota and all manufacturers have non physical interfaces for the tpms now. Most can only be accessed through the DLC or an onboard procedure.
Old 10-15-2010, 05:03 PM   #4
stschaub
Drives: 2009 Yaris 3 door hatchback
TPMS reset
On a 2009 3-door, where's the reset switch?
stschaub is offline   Reply With Quote
Old 10-15-2010, 10:27 PM   #5
It doesn't have a physical switch. It can only be manually reset using the Toyota Techstream tool:
3. CLEAR DTC
After repairing the malfunctions, clear the DTCs.
(a) Turn the ignition switch off.
(b) Connect a Techstream to the DLC3.
(c) Turn the ignition switch to ON and the tester on.
(d) Enter the following menus: Chassis / Tire Pressure Monitor / Trouble Codes /
(e) Clear the DTCs following the prompts on the tester screen
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
