Old 10-10-2010, 12:35 PM   #19
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
TPMS Reset
Originally Posted by DebbyM46227 View Post
I couldn't tell which it was. I looked at the dashboard each time I aired one up, and it didn't go off until I did the last tire.
It takes a little while for the TPMS to recognize that the air pressure is back to acceptable levels. Sometimes you will actually have to MOVE the car in order to initialize the reset. I have also had to revert to the button reset method on 2 occasions, as it would not reset by itself. The button method:
Press and hold in the TPMS Reset button and then turn the key to the engine run position, wait a few seconds and the light should go out. If ALL the wheels show correct pressure, an it still illuminates the (!) driving a short distance usually resets in about 2 blocks of travel. (It's a pain eh?)
bobolinko is offline   Reply With Quote
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
