Old 10-13-2010, 07:29 PM   #1
sickpuppy1
Drives: 2010 Yaris Sedan
Do you need to leave the card in the slot or does it just load from that slot?
Old 10-13-2010, 09:27 PM   #2
Dragracer
Yaris Noobie
Dragracer's Avatar
Drives: 2010 Yaris 3 Door
Mine is installed! What a freaking nightmare!
The basic install was not too bad. I had to slot the original mounting brackets as the radio set too far forward. Once I did that, the install was easy. I mounted the GPS antenna on the black plastic filler under the wipers. I already had the XM radio antenna mounted there. The GPS antenna is similar in size and shape, and both blend in very well. Photos are below.
The manual SUCKS! It took me forever to figure out how to pair my phone to the radio via blue tooth. Then the GPS came up in Chinese even though the language was set to English, and all other functions were in English. Finally figured out the GPS didn't know where to find the software. After programing in the sd card to the gps, all is well!
On mine there is a pink wire marked "park". This wire must be grounded to get a dvd to show up on the screen.
Here's where my XM antenna is mounted.
Here's the GPS antenna mounted there as well.
Here it is installed and running.
And here's a photo of the back of the unit.
I'm having a drink now!
Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
Dragracer is offline   Reply With Quote
Old 11-02-2010, 03:05 AM   #3
amanda_84
Drives: 2010 Toyota Yaris YR
Send a message via MSN to amanda_84
Hi, i'm wondering how you mounted the GPS antennae under the wipers as id really like to do this but I've not really don't much in tinkering to cars! Did you have to drill a hole or 'grommet' somewhere to thread it through?? (I don't even really know what a grommet is!).
Also...does any one know if the pre-loaded GPS software is upgradeable? OP said he put different GPS maps on a bigger card - how do you get the maps?
cheers for any help guys,
Amanda
P.s. I'm about to go install the HD now yippeee
amanda_84 is offline   Reply With Quote
Old 10-14-2010, 12:26 AM   #4
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
I don't know. I need to test that tomorrow (was getting dark on me). There are 2 slots, one on the left and one on the right. On the right one I have my music, videos, etc. The left one has the GPS software stick in it. If I have to leave it, I don't mind. It's not in the way.
chrisj is offline   Reply With Quote
Old 10-15-2010, 10:14 PM   #5
hyprmiler
It's cold in Wisconsin...
Drives: 2008 and 2009 Yaris Sedans
I have a 2008 and 2009 sedan, will this work for me? What parts do I need (silver plastics) to cover / go around the unit
hyprmiler is offline   Reply With Quote
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Used Kenwood 7037 Double Din Touch Screen +10 Disc Changer ! micquek Items for Sale by private party 0 12-31-2009 08:31 AM
Getting ready to get a DOUBLE DIN touch screen player, NEED INPUT! Syroyizhka General Yaris / Vitz Discussion 12 04-08-2009 10:26 PM
Decent eBay deal on harness and double DIN kit Sodium Duck In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2009 12:04 AM
