Old 10-14-2010, 11:16 AM   #1
magnum23
Drives: Blue,Sedan
I tried to get a read between the blue and brown wires with a digital multimeter, but It dont display any voltage, Im not really sure but I think Im doing it right. I used a Craftsman digital multimeter, put the knob in the VDC section, in the 20 value, and the cables the black in com, and the red in V, mA. I tried in the end of the plug and directly to the cable and nothing.
What Follows?
Thanks in advance.
magnum23 is offline   Reply With Quote
Old 10-14-2010, 11:23 AM   #2
What Follows?
Thanks in advance.
You have the meter setup properly. The important thing is to make sure that the metal tips of the meter probes are actually touching the metal of the connector pins. You want to go in from the side where the blue and brown wires enter the connector.
Also, make sure you have the key in the ON position when taking the measurement.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
