#1 | |
![]() Drives: 2008 Yaris S Join Date: Oct 2010
I have 2 connected to the parking light switch wire under the column and 1 connected down there by that relay. The remote start manual says I can connect 1 to a standard 12V source for + switching and ground for - switching, so I guess I should put 1 to chasis. Thanks for the clarification! edit: Yeap, that worked. Thanks again for the clarification on the switching! |
#2 | |
#5 | |
Headlights (I have a low current neg headlight output) Door Triggers and type (have pos and neg trigger wires) Also have aux outputs for various things such as remote window roll up...would be great if I found where to tap the windows up. Oh, I have a Prestige APS-997N... |
#6 | |
Door triggers (negative input when door is open): FL-red wire 4A-21, FR-light blue wire 4A-24, RL-green wire 4A-5, RR-light blue wire 4A-20, Trunk/Hatch- Sky blue wire 4A-7 If the alarm only has one input for the 2 or 4 doors, you can tap all wires together. Auto window up/down module install: http://www.yarisworld.com/forums/sho...3&postcount=39 |
#7 | |
You are awesome! Thanks! Hopefully I can get these last few connections in tomorrow. |
#8 | |
All the wires match up except Green Pin 5 is Yellow on mine and There is nothing in Pin 20; there is a Blue in 19... With the windows...do I have to have this additional module? The way my manual reads it will do auto-up without any additional modules... Can I just tap the Up Motor wires on that chart? Also, something else I noticed, my horn is not sounding when it should with use of RS/Alarm. I tapped the wire under the column like your document said... It is negative switching right? I need to get you a 6-pack for all this help! |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
