Old 10-14-2010, 06:56 PM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
You would probably want to go with the first hub choice since it does have overload protection. The resistor idea I would think would work for you just fine like Shinare has stated. I guess the bigger question would be the amp rating and draw if you had for example all 7 or 10 ports drawing juice right? The 7 port unit only provides 100mA per port and the 10 port unit doesn't list a per port rating.
Old 10-14-2010, 07:20 PM   #2
Astroman
Modded Moderator
Astroman's Avatar
Ok I'll go with the first hub, as also it would be cool to be running 10 ports if I ever needed that many. I even looked at the manufacture site and couldn't get a per port rating, but honestly other than the hard drive or DVD, most won't be drawing that much power anyway.
DIY Powered USB Ports BailOut DIY / Maintenance / Service 27 02-22-2017 10:17 AM
Non-Yaris Audio install help needed Revsson In Car Entertainment + Electronics (audio / video / alarm) 18 08-17-2009 11:47 AM
DIY aftermarket steering, hub, quick release install AlainMikli DIY / Maintenance / Service 17 07-20-2009 06:01 PM
