Old 10-14-2010, 07:56 PM   #1
adam1981
Drives: 2008 Yaris S
Very good - The wording in the remote starter manuals can be mighty confusing.
For the additional alarm wires, post up what you need and I'll add all of them to the document.
Right now from what I can remember this is what else I need :
Headlights (I have a low current neg headlight output)
Door Triggers and type (have pos and neg trigger wires)
Also have aux outputs for various things such as remote window roll up...would be great if I found where to tap the windows up.
Oh, I have a Prestige APS-997N...
adam1981 is offline   Reply With Quote
Old 10-14-2010, 09:48 PM   #2
Headlights: No low current tap, (~5A for low beams) - negative trigger, sky blue wire in pin 8 of headlight stalk connector.
Door triggers (negative input when door is open):
FL-red wire 4A-21, FR-light blue wire 4A-24, RL-green wire 4A-5, RR-light blue wire 4A-20, Trunk/Hatch- Sky blue wire 4A-7
If the alarm only has one input for the 2 or 4 doors, you can tap all wires together.
Auto window up/down module install:
http://www.yarisworld.com/forums/sho...3&postcount=39
Old 10-14-2010, 10:30 PM   #3
adam1981
Yeah, it said I would prob have to use a relay on the lights.
You are awesome! Thanks! Hopefully I can get these last few connections in tomorrow.
Old 10-15-2010, 01:20 PM   #4
adam1981
4A is the top left harness on that main panel behind the pull out pocket right?
All the wires match up except Green Pin 5 is Yellow on mine and There is nothing in Pin 20; there is a Blue in 19...
With the windows...do I have to have this additional module? The way my manual reads it will do auto-up without any additional modules... Can I just tap the Up Motor wires on that chart?
Also, something else I noticed, my horn is not sounding when it should with use of RS/Alarm. I tapped the wire under the column like your document said... It is negative switching right?
I need to get you a 6-pack for all this help!
Old 10-15-2010, 01:42 PM   #5
Check the 4A wires relative to this:
For the windows, you can use those same wires if your system has the auto roll up feature. Just make sure that it is rated for high current (20+A) or else you will need relays.
For the horn, the black wire on the spiral cable connector is definitely it, and it is definitely negative switched. Check your tap to make sure it bit all the way in.
Old 10-15-2010, 01:47 PM   #6
adam1981
Attachment 37551
Yeap, that is the connector and the direction I was counting the terminals... So, I guess my green wire is yellow and not too sure about the discrepancy on blue 20. I will recount again, but have 4 or 5 times now...
Old 10-15-2010, 02:05 PM   #7
OK. I just noticed you have an 08 sedan. On that 4A-5 is yellow instead of green.
I have an 08 Sedan fuse box on my test bench, and I also see the missing wire in 4A-20 (which the EWD for an 08 sedan says should be there). Those two wires are actually tied together as a single input into the ECM, so you probably only need the yellow and that is probably the reason for the lacking blue.
Old 10-16-2010, 09:56 PM   #8
adam1981
Identified all of the wires and confirmed they are the right ones! Thanks for your continued help! However, they have proven difficult to tap because of the little slack in the harness.
So...I am going to have to connect all the door and truck triggers together. Got to thinking though, when I do this - the Driver Info Center is going to show all doors opened when only one actually is...
Do you know if I could place a diode in line with each of the taps before I tie them together to prevent the problem caused by just tying them all together - to maintain the integrity of each circuit? Will a diode pass the negative/ground provided by the switching?
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
