Old 10-14-2010, 09:20 PM   #1
magnum23
Drives: Blue,Sedan
I will be running that wire tomorrow morning then, Do I need the special connector listed for adding the connection to the ECM or could I tested just passing the cable through the space where it goes on the black plug that goes to the ecm?
Do a regular cable connector works? ( the little square ones)
Thanks for your help!!!
magnum23 is offline   Reply With Quote
Old 10-14-2010, 09:23 PM   #2
You definitely want to get one of the real pins for permanent installation, but you can try the "shove a wire in" method for testing. I wouldn't try any other type of pin, as if it gets stuck you'll have a real mess.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
