Old 10-15-2010, 02:58 PM   #1
magnum23
Drives: Blue,Sedan
Ok, I did a road test and is working, but for some reason is not showing it on the cluster, and it have the light for it, the cluster part number is 83800-52S10
157540-8052
Thanks in advance.
magnum23 is offline   Reply With Quote
Old 10-15-2010, 03:56 PM   #2
157540-8052
Thanks in advance.
OK - 83800-52S10 is listed as being "Puerto Rico Spec". That must mean that for whatever reason the CC indicators are not active. Since your ECM fully supports CC, it sends the messages over CAN bus to the cluster, but your cluster just ignores them. You could pick up a US spec cluster off Ebay and then you'd have the working indicator.
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
