Old 10-15-2010, 05:03 PM   #1
stschaub
Drives: 2009 Yaris 3 door hatchback
TPMS reset
On a 2009 3-door, where's the reset switch?
stschaub is offline   Reply With Quote
Old 10-15-2010, 10:27 PM   #2
It doesn't have a physical switch. It can only be manually reset using the Toyota Techstream tool:
3. CLEAR DTC
After repairing the malfunctions, clear the DTCs.
(a) Turn the ignition switch off.
(b) Connect a Techstream to the DLC3.
(c) Turn the ignition switch to ON and the tester on.
(d) Enter the following menus: Chassis / Tire Pressure Monitor / Trouble Codes /
(e) Clear the DTCs following the prompts on the tester screen
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
Tire pressure sensors ztlonewolf DIY / Maintenance / Service 14 04-25-2009 05:19 PM
Higher Tire Pressure captainm27 General Yaris / Vitz Discussion 46 01-27-2009 10:17 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
