#55 | |
der Zeck
#56 |
![]() ![]() Drives: Flint Mica AT Sedan Join Date: Nov 2006
ok, a little bit of a flip of the topic, but would anyone consider sending/selling this module my way? feel free to PM me if so. :) i actually prefer DRL and wouldn't mind the insurance discount either. any reason why this wouldn't work on my sedan?
#57 |
Your car needs to be pre-wired from the factory at least, to have the DRL's.
Maybe poke around online, and see. I remember all my BMWs came pre-wired for lots of things. |
#58 |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
What Kelven HID's are those .. just curious. I have h4 from my old 240 but one ballast went bad (Philips). Now is there a switch to turn on and off the DRL's? I know in my girl's mother's Trailblazer, there is that option. If not, is there an online FSM that can let me know where the remote wire is so I can just create one without taking out the box?
Reason being is that I do like the idea of the DRL. This way I can just have the switch off and then after I start the car, turn them on. Yeah yeah before i go you're probably asking yourselves why the hell is a Noob going to go through all of this when he can just pull out the box and do what Chris does? It's because I'd rather have just the headlights on (like DRL's) and them on only until I have to turn all of my lights on at night. I know it may seem like a PIA job to go through all that but I like challanges >:)
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
#59 |
Glad to help.
#60 |
toyota
DRL question!!
im actually wondering about its wiring could you just cut the wire going thru the drl should be just one of each side then re ground them and still ran it thru a separate bulb.. just a thought..it separates them from ur hid...
#61 |
Then where would you mount an extra bulb at? Seems like a lot of trouble, to keep DRL's.
I drive during the day with my HIDs on, as its quite a little car we drive, and its bad enough A-Holes dont see you... |
#62 |
toyota
well i always thought its not always good to have the hid on due all the time due to its life hours.. then again im not an hid expert...sucks that i read that you lose ur high beams as well...dang...
#63 | |
I chose to go with only a low beam H4, and turn my fogs into high's like Violin did. |
#64 | |
#65 |
~ ambient one ~
what about what I mentioned in the last page? Is there a way to just switch it instead .. I'd rather have the option of whether I want to have DRL's or not (comes in handy when trying to be stealth at night).
AMBIENTLIFESTYLE
#66 |
toyota
chris drl question
now disconnecting drl relay.. is it possible to hook that up to fog lamp instead..so fog light are always on and use that as my drl instead!!...
#67 |
I don't know if anyone has figured that one out, but it wouldn't easy as it would involve fiddling inside the ECU.
Why not just run a line from a switched circuit to the fog lamps so they come on whenever the ignition is switched on? Use a blank circuit or trigger a relay from an existing circuit and run a wire (fused) from your battery. |
#68 | |
![]() ![]() Drives: 2007 Yaris Liftback Join Date: Sep 2006
#69 |
YOU GUYS GOT DRL's! WTF I WANT DRL's...i didnt know the liftbacks had that w/e
#70 |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
did my disable last night, now im stealth......
http://www.carid.com/toyota-accessories/ site has a FEW interesting yaris items..... |
#71 |
Easiest Mod My ASS!
There is a Metal bar that surrounds my DRL Relay… I put my hand in under it to pull out the White plug… AND I FUCKING CUT MY THUMB… Pretty fucking deep too! Now it seems all I need to do is droll on my-self a little AAAAhhhdduuuuhhhhhhhhhh But at least I got it!
#72 |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 03:12 PM |
