Old 10-16-2010, 10:51 AM   #29
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by donchae View Post
you think there's gunn be problems regarding the tire pressure sensor thing with the VW rims?? and what tire size would you recommend with that? 185/60/15?? i am still confused about these numbers.. what does the 185 stands for? and the 60? i know that the 15 is the size of the rims.. and offset is how much the wheels are sticking out right?
Not sure if the TPMS will fit those old VW wheels. Don't know the wheel specs, except you state offset is +35mm... in which case I'd probably go with 185mm or possibly 195mm tyres.
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
noob question.. msfire671 Cosmetic Modifications (Exterior/Interior) 9 02-26-2010 11:58 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
noob question redduck Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-05-2007 06:34 PM
Question about Rims MrJester Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 03-06-2007 10:16 PM
