Old 10-18-2010, 01:46 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
That would be awesome. If I happen to come across one I'll be happy to ship it your way.
Old 10-20-2010, 09:41 PM   #2
I got my hands on an 07 ECM from an A/T today. It's part number 89661-52F11. I tried it on my test bench and when I "switch gears", both my 08 and 09 clusters show the position on the ODO LCD.
So, it's the 07 cluster that doesn't respond to gear change CAN message, rather than the 07 ECM not sending it.
Old 10-22-2010, 02:22 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Now this is starting to get interesting. Why would the cluster "have" a spot for the gear selection, the ECM is sending the signal, but it's not active?
Weird...
Old 10-22-2010, 02:46 PM   #4
Weird...
That's nothing - Our friends in Australia get a cool digital cluster that has the ability to display fuel efficiency, but it's not active either. When you are designing something like a cluster, you add all of the hardware up front, and then in software you enable it as you see fit. You never want to have to go back and redo the hardware if you can avoid it. The problem though, is that upgrading the cluster SW is not a field doable thing.
Hi, question about 2007 Yaris and Ecometer... thepliosaur1 Fuel Economy Forum 3 07-11-2010 05:56 PM
2007 Toyota Yaris Temperature Question bhola General Yaris / Vitz Discussion 17 06-25-2010 06:46 PM
2007 Yaris Sedan Automatic 4 door Jonny878 Cars for Sale by private party 1 12-29-2008 10:41 PM
