Old 10-28-2010, 12:39 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by Qmobile View Post
ok so I've encountered by a lil set back. I've tried advanced auto parts....no........they told me to go over to Fastenal...still no dice :( so looks like I'm stuck
set back for what? What are you trying to find?
That first pull can be a pain. Like it just doesn't want to move, then all of a sudden it comes out, and you hopefully don't fall.
Colin Chapman disciple
Old 10-28-2010, 04:59 PM   #2
padre1964
padre1964's Avatar
Drives: I'm back !! 2012 Toyota Yaris
i removed the rear seat because i wanted a more level storage area. found the proper socket at Autozone to remove the bolts. i left the seat support in and bolted the wood frame to it. also didnt want to remove the spare so i just raised the floor to level it out.
best mpg so far, 46.1 !! Still shooting for 50 !
padre1964 is offline   Reply With Quote
Old 10-28-2010, 10:34 PM   #3
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Originally Posted by Klink10 View Post
Q....setback is? If it's the star bolts check out Northern Tool if you have one close by. I would say Sears but they might be iffy. If the stars are stuck spray with PB Blaster (Napa) and let them soak. Remove with tools using loosen a little ....tighten a little. Was going to use my air powered stuff but thought better of it as they probably would have snapped.
Yeah star bolts.....I'll look to see if there's any norther tool round here
star bolt socket
And it's not (according to my "test") a regular star bolt(torx head) it's like a regular bolt but with the torx head.....if that makes ANY since
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 10-28-2010, 09:02 AM   #4
Klink10
Klink10's Avatar
Old 10-28-2010, 10:39 PM   #5
33OH
Drives: '08 Yaris
You can leave the seatbelts in for now, just remove the backseats and see if you like them out.
Old 10-28-2010, 10:55 PM   #6
dvlnblkdrs
Shush!
dvlnblkdrs's Avatar
Drives: 2007 toyota yaris
i took mine out ages ago.. i had the 60/40.. the rear spare tire cover does NOT stay put, i repeat DOES NOT STAY PUT. i ended up taking it out.. also it bumped my rear back up to stock height, so i had to adjust my coilovers...and the car is now front end heavier in losing 100 lbs in the rear...so i gotta brake a lil sooner and lighter...
but its all worth it in the end, now i corner and race around town like a champ... sold my backseat to justjesus...
Old 10-28-2010, 11:04 PM   #7
why?
why?'s Avatar
Drives: Yaris LB
it is called external torx. They are relatively new from what i recall. My socket set was set up to remove them just fine. But the set was made to deal with like every single possible bolt you could come across.
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Back door panel removal ('00 Vitz) HELP ! Demon DIY / Maintenance / Service 2 09-27-2010 08:42 PM
Sedan rear seat removal guzziknight DIY / Maintenance / Service 4 06-11-2009 05:29 PM
