Old 10-20-2010, 12:49 AM   #16
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
No lol. Garm and another member, 1NZYaris and maybe CTScott I believe, worked on making a total Plug N Play fog system for the Yaris. I dont know for sure if it works for the Sedan in the same way but it probably does. Anyway, before this PnP kit, you would have to run wires through your firewall to get the lights to come on and off. However, the guys figured out that Toyota already installs the wires through the firewall for you. Even if you dont have fog lights, the fuse box connection is already wired which feeds to the steering wheel column connector D4. What Garms kit does is plug into the D4 connector to a switch. His kit also comes with the actual fog light wires that the fogs themselves plug into. That part plugs directly into the fuse box. So Garms kit is total PnP, no stripping, cutting, soldering, etc required. Hope this helps.
Edit: Btw, I know all this because I just finished doing it on my liftback last weekend :) Hopefully another Sedan user can comment on the status of Garms fog kit for the Sedan.
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
LED Back Up bulbs installed fnkngrv Cosmetic Modifications (Exterior/Interior) 15 12-20-2011 06:30 PM
Looking for Pics with Nokya bulbs Arkhangel Photo-Video-Media Gallery 4 09-19-2010 07:31 AM
FS: Yellow 2500K Foglight Bulbs 33OH Items for Sale by private party 5 07-23-2010 02:31 PM
6000K H1 HID bulbs Saggio Items for Sale by private party 10 12-12-2008 06:19 PM
Side Turn Signal Lights bigsky2 Cosmetic Modifications (Exterior/Interior) 15 08-24-2006 06:06 PM
