Old 10-20-2010, 07:04 PM   #1
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
Were you able to get the bolt out?
main 14mm bolt ajustment is hard
last meccanic tried too much to adjust the alternator..this is the reason why the bushing is "turn in" inside the casting
no I am unable to remove bushing or make it move
I really need help !
Siffleu is offline   Reply With Quote
Old 10-20-2010, 07:37 PM   #2
OK - I was thoroughly confused until I just took a look to refresh my memory. That part is not designed to be replaced. I think I would either drill it out, or cut it out and then just use a longer bolt with a washer and a lock nut.
Old 10-20-2010, 08:58 PM   #3
Siffleu
Siffleu's Avatar
Drives: Yaris 2006
how about grinding the casting near pan of the bushing ?
Old 10-20-2010, 09:09 PM   #4
Sure. The bottom line is either get it out of there or get it to let you pass a bolt through it. Another option would be to pull the alternator and weld it so it won't rotate.
Driver door won't open, jammed cable? Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 13 02-24-2011 01:14 PM
