Correct on single vs. dual filament, and it's really just the front and rear parking light bulbs that you could accidentally reverse (front gets single, rear gets double).
I would pull all of the lights and go one quadrant at a time. Once you get the first quadrant working completely and correctly, you move onto the next. After the first quadrant add one bulb at a time to the next quadrant to reduce your variables. |
Not quite a noob
Okay, after checking all fuses I have come to the conclusion that it is very probably a relay. What doyou mean by Quadrant? Like FR, LR, FL, RL? (Front right etc.*)
#3 | |
The only relay I could see getting damaged from what you have done is the flasher. It's pretty hard to damage a simple mechanical relay without first smoking a fuse. |
Not quite a noob
Alrioght taking out the rear brake lights have yielded some interesting results:
Both rear lights are not in, all lights return to normal One rear brake light is put in, all lights remain normal, but brake lights still do not apply Both rear brake lights are in, stuff hits the fan- electrically speaking. Is there a relay or fuse specifically dedicated to the brake lights I could have fried? EDIT: Derp, the flasher. I thought that only controls the signals. Now my problem is getting the little sucker out, it's wedged in tight. |
Not quite a noob
7443 is a type of bulb, a flasher module is a mechanical switch, if you will, powered by electricity to "activate" when current is applied, for instance if I apply the brakes, electricity will run through the module, and allow current from the battery to flow to the lights (this is simplified). LEDs require less power than incandescent bulbs, and therefor have less resistance to electric current. The car thinks that this is because a bulb is out and it flashes very rapidly at you when you attempt to signal. To fix this, with LED bulbs, you would need to add resistance to the line, or replace the module so that the car thinks that everything is as it should be.
EDIT: Alright CT, I took out the flasher module, and I turned the driving lights on, the rear brake lights came on, but not to brake capacity. They do not activate even when I have no driving lights on.. though upon reflection that doesn't determine where the problem is still. EDIT2: Upon further troubleshooting, we have determined it is a relay. Though the problem is now, I don't know which relay on the instrument panel it is. Last edited by Betrivent; 10-22-2010 at 08:09 PM. |
The brake lights don't have a relay in their circuit, so for them, check the STOP fuse in under dash fuse panel.
Not quite a noob
I did, and all the fuses are fine. This is infinitely perplexing then. Howeber, I did check etimago's EWD and found that the stop signal goes through some sort of BOX, if you cancall it that, on the diagram, I just assumed that wasa relay
Not quite a noob
#9 | |
For the heck of it, replace the stop fuse. It might not be fully popped, but might be so thin that it's causing a wicked voltage drop.
Not quite a noob
I will try that tomorrow, I have a gut feeling it's something really simple like that too, but my middle stop light works? Like the one at the top of the hatch. Shouldn't it also fail if my fuse is blown/malfunctioning?
That would actually make sense, as the center light is LED, so it draws very little current in comparison to the bulbs.
Not quite a noob
Ahhh I see. I will check that right after I get some coffee.. zzzzzz
EDIT: Didn't get around to it today, will check tomorrow. Last edited by Betrivent; 10-24-2010 at 03:03 AM. |
Not quite a noob
Alright, so update. I tried replacing the STOP fuse in the 9 position on the fuse panel under the dash, and no luck. I've been thinking, if when I plug in two LED bulbs, and one comes on, and when I plug in two incandescent bulbs, and NONE come on, could it be I've fried something that provides the two sockets with power? I can only think it's something near the front of the car, since I've examined all the electronics in the back of the car.
EDIT: So obviously it's got to be between the fuse and the lights, that there is a problem. Could i have partially burned the junction connector? |
#15 | |
Not quite a noob
I will do my best. But I am skeptical that both have failed? Especially since when I switched LED bulbs to troubleshoot, one bulb always worked, regardless which socket it is in, and the other did not, also the original bulbs did not work at all again after I screwed up the first time.
#17 | |
Not quite a noob
I will get you pictures, but it will have to be later since I do not have a garage to work in and need to wait until later when I have access to one.
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Green LED Dome Light and Underdash LEDs Installed | fnkngrv | Cosmetic Modifications (Exterior/Interior) | 11 | 08-20-2010 12:38 PM |
| going LED | Qmobile | Cosmetic Modifications (Exterior/Interior) | 23 | 07-30-2010 07:39 PM |
| Interior LED Ricey Problem | xbr3akd0wnx | Cosmetic Modifications (Exterior/Interior) | 10 | 05-06-2010 08:50 PM |
| Cheap eBay LED Strip vs V-LED Strip | Kaotic Lazagna | Cosmetic Modifications (Exterior/Interior) | 1 | 03-18-2010 08:06 PM |
