Here's a PDF that I put together for Mgargano, who installed the DEI 530T Auto window module, which allows two windows to do both auto up and auto down. If you have a 4 or 5 door, you can use two modules:
The Yaris is a "Type A" system, so set switch 5 to the OFF poistion. For the Resistance setting, use the following: SW1-OFF, SW2-ON, SW3-ON, SW4-ON, SW5-OFF http://www.yarisworld.com/forums/att...2&d=1253493376 |
#2 | |
USAF_SrA_E-4
hey Scott I want my windows to come down and up when i click the Aux button on he remote starter clicker. any ideas?
That same module will do exactly that. It either can either auto open/close by quick press of the window switch or by input from a remote starter.
#4 | |
USAF_SrA_E-4
how do i link it to my remote?
#5 | |
![]() ![]() Drives: 2007 Yaris Hatch Join Date: Jul 2007
Kaeon - 2007 Toyota Yaris Hatch |
Try the different settings in the DEI manual until you find the ones that work for your car. Resistance will vary based on age and lubricant state for the power window motors.
