![]() Drives: 1.4 D Join Date: Nov 2010
smokey 1.4 D - only 52K miles
hi all
I've just bought a Yaris diesel on 52K miles. It produces white smoke if you give it welly but otherwise runs sweetly and quietly. Is this normal for a 52K car? I rummaged back through it's history and at only 5K miles someone put petrol in it. Also at 42K miles it failed its yearly exhaust emissions test. I believe this was rectified using some sort of fuel cleaner or something. Any ideas what could be wrong? Also it tends to wander and it is annoying having to constantly keep it in a straight line. Best Dude |
![]() ![]() ![]() Drives: 2010 Yaris Bayou Blue 3DR Lift Join Date: Sep 2010
Since it's a diesel engine, it might be an injector issue. One of them might be dirty. Buy a bottle of diesel injector cleaner. Do this for 1 or 2 tanks and see if it clears up.
Only reason why I'm suggesting this is that you said your car runs fine but only get white smoke when you give it welly. The wandering is an alignment issue. Get your car an alignment as soon as possible. Good luck and congratulations on the purchase! |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
what MPG do you get with a diesel?
hi Freedan
Cheers, I'll try that, thanks. Tonight I did 25 miles on approx 1.5 litres. I think this equates to about 75 mpg! Not bad at all, especially since it was a mix or urban and motorway driving. Apparently the 1.4 D will do 85mpg when driven like a vicar on the motorway. I have to say the engine seems tiny and very quiet, but it pulls well even in 5th gear. Impressive. Dude |
#5 | ||
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I'll assume "motorway" means "highway"? Then again, the literal meaning could mean any street that a vehicle drives on.
#6 | |
Parallel Parking Pro
Apparently the 1.4 D will do 85mpg when driven frugally on the highway. vicar [ˈvɪkə] n 1. (Christianity / Anglicanism) Church of England a. (in Britain) a clergyman appointed to act as priest of a parish from which, formerly, he did not receive tithes but a stipend b. a clergyman who acts as assistant to or substitute for the rector of a parish at Communion c. (in the US) a clergyman in charge of a chapel
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
^Thanks.
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 10:54 PM |
| Man hits 1 MILLION MILES in Ford F-250... in four years!!! | Kal-El | Off-topic / Other Cars / Everything else Discussions | 6 | 10-30-2010 11:19 AM |
| Putting a lot of miles on my '10 so far, how long should I expect to get out of it? | JerseyJeff84 | DIY / Maintenance / Service | 14 | 09-01-2010 04:24 AM |
| What's ur longest drive in a Yaris without stopping(cept gas)? | Yawesh | General Yaris / Vitz Discussion | 46 | 04-21-2009 02:36 PM |
