Old 11-03-2010, 12:50 PM   #1
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
I've thought about adding heated mirrors as well. Especially this morning when I was driving to work and my mirrors were all frosted up. I too have an '07 HB. Would this be a simple install? Do the heater elements mount behind the existing mirrors, or do I have do get new mirrors with elements already installed?
Eatoman is offline   Reply With Quote
Old 11-03-2010, 01:01 PM   #2
On an 09+, the wires are already there between the power mirror connector and the kick plate connector on both sides, so on the mirror side you would just have to snake a wire through the mirror mount and connect it to either a set of OEM heated mirror glass pieces or a set of the stick on aftermarket mirror heaters. On an 08- you'd have to run the wire all the way from the mirror, through the door and into the kick plate area.
Old 11-03-2010, 01:11 PM   #3
Eatoman
Eatoman's Avatar
Thanks CTScott! I saw in another thread that you mentioned something about a heated mirror kit? How would I go about finding this kit? Is it OEM?
Old 02-19-2015, 03:58 PM   #4
bairjo
CTScott, I am doing this install on my 2010. I have the door panel off and the three wires for the power mirror, black red and white, channel down and plug into a plug in the door. This plug they plug into also has a light blue and a purple wire leading into it. Are these the heating element wires? If so , just wire my leads from the element in the mirror directly into these?
Old 02-19-2015, 09:43 PM   #5
Those two wires are for the OEM mirror heaters. They only go as far as the connector at the kick panel.
Old 02-19-2015, 10:49 PM   #6
bairjo
I understand now...thank you. By the way my mirrors do pop off like the ones in the link you provided above but are not glued in place. They snap into the frame with a little sticky putty in back of them. I will be posting a video of my install if anyone is interested.
Old 08-26-2015, 11:53 AM   #7
bad
Winterizing
bad's Avatar
Drives: 2010 Toyota Yaris Hatchback
video of heated mirror install
Hey, I would be interested in that video, please.
Thanks!
33.7 mpg in PA
bad is offline   Reply With Quote
Old 08-26-2015, 07:37 PM   #8
bairjo
Thanks!
Here ya go...it's a little hard to follow at times....just hit pause when you are at one of the spots in the video. Good luck with your install.
https://www.youtube.com/watch?v=5pkbGxqhYZI
Heated Side View Mirrors goku87 DIY / Maintenance / Service 27 01-26-2016 05:23 AM
Unlinking heated side mirrors / rear defrost Alezius DIY / Maintenance / Service 9 11-03-2010 01:29 PM
heated mirrors on 09 model? DOMAV General Yaris / Vitz Discussion 34 10-27-2009 04:13 AM
Replacing manual mirrors with powered plz help MikeB DIY / Maintenance / Service 0 05-27-2009 09:55 PM
Will '09 Heated mirrors fit on an '08? goku87 DIY / Maintenance / Service 1 11-17-2008 05:39 PM
