![]() ![]() Drives: 07 lb jeep tj Join Date: Oct 2010
cheap sound deadening
had anyone here ever used peel n seal or any other lowes type sound deadening as a cheap alternative. I was replacing the rear speakers in my lb to find NO sound deadening at all all you can see it the sheet metal.
Roadrunner Jr.
Raamat.com is a good quality site to get deadening.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
http://www.raamaudio.com/
it's a good starting point. This is another option, but all depends on what you want! http://www.soundproofing.org/ Derick
. CLA 250, 4MATIC |
Roadrunner Jr.
That first option derick gave is the one.
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
what would you put ? peal and seal every where in the car ?
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
Modded Moderator
![]() There ya go. |
If I where you,
I would start putting a complete layer of MAT from raamaudio.com in the TRUNK Then will treat the same way the front doors This would help more acoustics of your woofers/speakers than blocking road noise, but it's a good start D.
. CLA 250, 4MATIC |
What quantity will I need to treat the front door and the trunk ?
HOW MANY And for the floor it's MAT + MLV ?
"And for the floor it's MAT + MLV ?"
MLV it's a sound barrier and it's not cheap. (works great on the floors, wheel wells, Pillars and doors). Works in junction with CLD Tiles (or a full layer of MAT) + CCFoam. You can add a layer of CCFoam on top of the Mat then a layer of MLV on top of the CCFoam this system would help reduce road noise! D. |
And just to have a good sound quality....only use MAT would be great ?
Sound quality comes from your equipment
Road noise doesn't let you hear your music at low levels Mat helps to prevent vibrations, produced by woofers, and road noise. |
So with my big woofer that I want to be loud....i use mat ? is that right ?
in the trunk and the froont door ? so it will prevent vibrations that we dont want....the woofer vibrate parts of the car so it make the sound being bad ?
Have you ever heard a car with a loud system and the trunk + license plate vibrate like crazy! that is why you use MAT. But if you use only MAT to prevent vibrations and block the road noise you would need at least 3 or 4 layers of MAT. That is when using MLV comes appropriate.
Thats what I mean with vibrations we don't want like the license plat...:)
So I'll put One layer of MAT in the trunk and in the front door :) on roll is enough ?
#17 | |
I didn't use a lot of MAT, most of my deadening was CLD Tiles + CCF + MLV and then I used about 45 sqfeet of MAT, to feel the gaps (wheel wells & trunk) and front doors. |
I for sure dont want to go crazy as you went....remember I'm only a student !
I'll go with with it !
| 2008 Yaris sedan ‘S’ sound deadening project. | Herbicidal | In Car Entertainment + Electronics (audio / video / alarm) | 155 | 09-04-2011 11:56 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
