Old 11-06-2010, 09:55 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
NST pulleys - these were on when we did the dyno runs, and for most of the season. Once we started running 7300+rpm on the track the crank pulley failed, so we went back to stock.
am i reading this right? you had the NST pulleys installed, then when u tweeked the engine and started running higher revs the NST crank shaft pulley broke? how bad was the damage?
also, im assuming that the NST pulleys are a bad idea for running past the stock rev limiter then?
this worries me cuz i just installed these guys and i autocross. sometimes on a quick straight i will stay in second and let the rev limiter bounce if there is a quick turn not to far but would be losing time if i go to third.
Old 11-06-2010, 01:01 PM   #2
Jason@SportsCar
I would not worry about these at all on a car with a stock limiter.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
