Old 11-05-2010, 04:58 PM   #1
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
What effect does lowered suspension have on MPG?
Old 11-05-2010, 05:10 PM   #2
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
My mods:
AFE intake
MI lowering spring
23mm UR rear anti-sway bar
Tanabe Medalion touring exhaust
I'm not sure about just lowering the car, but with the mods I did, my MPG went down drasticlly.
The urge drive spiritedly is just too much!! When I install that turbo kit that MI is selling, I just know my MPG will drop even more.
Freedan is offline   Reply With Quote
Old 11-05-2010, 05:17 PM   #3
lowering won't have any effect on the mpg assuming you drive the same.
Old 11-05-2010, 05:30 PM   #4
Flipper_1938
Old 11-05-2010, 06:25 PM   #5
brg88tx
Drives: 07 Yaris Sedan, Auto
i think lowering does help slightly. i browse on ecomodder website and many talk about lowering, moon caps, and belly pans to reduce drag.
brg88tx is offline   Reply With Quote
Old 11-06-2010, 04:00 AM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
After installing my AMR springs my MPG has not changed whatsoever.
Old 11-07-2010, 10:05 AM   #7
sickpuppy1
Lowering it the amounts we do and at the speeds we travel, it wont help mileage. Now if it were raised like a 4x4 then you would notice. The air turbulence under a raised vehicle creates more drag and lowers mileage. going lower creates downforce and actually more traction as a vehicle is pulled toward the ground. But this applies more to race vehicles that have smooth underpans to eliminate pockets and such....an also travel at much higher speeds than we do. LOL or even CAN,lol Aerodynamics and airflow management......
Old 11-07-2010, 10:28 AM   #8
MadMax
MadMax's Avatar
I think it causes a decrease with some people because they drive faster since the car handles better. Same is probably true with the rear sway bar.
Otherwise, the differences should be nominal...
Cheers! M2
Old 11-07-2010, 04:12 PM   #9
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
If you're one to chase MPG, it is a factor. If you're one who drives normally who happens to enjoy the mileage of the car, then it might not be too much of a difference.
For me, I notice some easier cruising speeds and I was able to *cough* coast a bit longer when the chance availed itself.
Old 11-07-2010, 05:36 PM   #10
Flipper_1938
Old 11-07-2010, 05:41 PM   #11
fnkngrv
fnkngrv's Avatar
^ Lowering is not going to be only for looks. My stability as well as turning radius increased ENORMOUSLY! This along with the rear sway bar have made driving on the open road a joy. I am not fighting the cross winds at all really. This was extremely apparent during my recent almost 1700 mile trip from Maine to Alabama. I ran into high winds during periods as well as high winds and heavy rains. With the springs and sway bar the car took it with ease and like a champ. I can easily compare this because in 08 I made 2 trips from Maine to Tennessee and those trips were pure hell. I was blown all over the road. It was the same when I bought the car in Minnesota in 06 and drove it to Maine 4 days after buying it.
Old 11-07-2010, 05:43 PM   #12
fnkngrv
fnkngrv's Avatar
Originally Posted by Flipper_1938 View Post
I'm not really chasing mpg's, but don't like taking it in the butt for the sake of good looks either.
I put a set of 17's on my old echo and it killed my gas mileage and overall acceleration by a noticable amount. After the first set of tires wore out, I went back to my steel wheels and hub caps.
For looks, I would like to drop it a little...but I don't want it to drop me below the 40 mpg that I am used to getting.
If you would like good food for thought check out my thread if you haven't yet on my trip summary this week:
http://yarisworld.com/forums/showthread.php?t=31696
I averaged over 36.5mpg with all of my mods and the car having a close to maximum payload...to me that speaks volumes.
Lowered Cars Please Read - Bump Stops!!! Galavoxx Wheels, Tires and Suspension Forum sponsored by The Tire Rack 46 11-11-2010 05:49 PM
3000 mi Summer Trip Log...MPG included! slothman86 Fuel Economy Forum 14 07-20-2010 01:15 PM
Better MPG in the City vs. Hwy Loren Fuel Economy Forum 21 01-29-2010 12:49 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
