![]() ![]() Drives: 01 Toyota Echo Join Date: Oct 2010
The front is 3.75" off the ground from the bottom of the air dam/front spoiler.
I have another question about the lift. Did you lift the back end at all? It seems like based on its design you can only lift it so much. Like you go with a slight larger spring but eventually. If you keep going larger it presses farther and farther down. It will add some inches but looks like the spring might pop out the side. |
#2 | |
Any idea where i can learn about other spring options? I'm sure they are standardized.
| 2010 Yaris lift | eric81 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 10-13-2015 08:57 AM |
| Finally bought a lift | CTScott | DIY / Maintenance / Service | 26 | 09-28-2010 09:09 AM |
| hood lift? | Qmobile | Cosmetic Modifications (Exterior/Interior) | 19 | 08-14-2010 09:35 PM |
| WeSellCarParts.com // Redline Tuning Hood Lift! | WeSellCarParts | WeSellCarParts | 45 | 12-18-2008 07:12 PM |
| FS: Redline tuning Hood Lift | yrsdrgn | Items for Sale by private party | 9 | 11-03-2008 08:15 AM |
