Old 11-18-2010, 10:03 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
depends on RPM. When cold (under 10°C) oil pressure is around 80-90 psi @ 1500RPM and above until it starts to warm up. My car is usually at about 68 psi at cruse (2500ish RPM)
^ if that's any reference to you.
Old 11-18-2010, 10:12 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Yeah that sounds about right for me as well.
I ask because I've had this bizarre leak from every filter I've used since I did the turbo install.
The mystery continues...
Old 11-20-2010, 08:40 AM   #3
Bluevitz-rs
I just had another idea as to the case of the backup on the return.
Everyone is thinking the return is too restrictive. Well has anyone considered there's a restriction in the PCV valve? If you had a build up of pressure in the crankcase, if the pressure isn't getting out the PCV valve there's only one other option, the drain line for the turbo.
Old 11-21-2010, 02:13 AM   #4
Focus_Sh1ft
This was actually my first idea as to leaking oil. I undoubtedly had a kink in my PCV line, so I ended up pulling it and putting a breather on like two days ago. Carlos was telling me it wasn't possible though, so I dunno. I'll be watching my intake carefully... My ongoing code, P0101, hasn't returned after clearing it when I put that breather on as well.
PETERPOOP, the coolant flow direction doesn't matter. Great progress so far keep it up
Old 11-20-2010, 08:19 PM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Progress so far...
Got the pan back on. Decided to go below the oil line. Installed the turbo manifold, turbo, and downpipe. The oil send/return line, and now working on the water line.
Tightened the bango fitting with this ghetto trick.
Got the manifold and turbo in place without removing the A/C line. We bolted the turbo to the manifold behind the engine, and then lifted it up and bolted it to the block. We didn't bolt it together first and then try and wedge it into place. It was easier to bolt it together while behind the engine.
Quick question. Getting ready to put on the water line to the turbo. I am going to get it from the throttle body coolant lines. Just wondering if it matters which direction it flows into the turbo? Not sure which is "in" and which is "out." Even with the throttle body lines, which is "in" and which is "out." Obviously I can't start up the car to see which way it flows from the engine. If anyone knows, thanks in advance.
Old 11-21-2010, 09:01 AM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
the cool water (inlet) should be on the lowest fitting of the turbo.
Old 11-21-2010, 12:29 PM   #7
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Crush washers are said to only need 12 ftlbs of torque to seal, usually i see them require about 85ft lbs torque to never leak. You might be better off shaving the sides of a wrench, or making a crow foot deal by welding a closed end side of the wrench onto a socket so you can get a wrench in there in some way.
Old 11-21-2010, 02:12 PM   #8
Focus_Sh1ft
I definitely agree - they need way more torque than advertised. Without taking the turbo apart I got them pretty tight but they still leaked. It's easy to take apart too - the only thing holding it together is that c-ring thing I think it's called.
There wasn't room to fit a 17mm socket on it, right? I can't remember, but I do remember not using a socket...
Old 11-21-2010, 02:33 PM   #9
Nexus1155
Drives: Audi
I'd take pics of the tools I made, but you shave down the edges of a wrench to fit it in there easier.
The crow foot is if you cut a box wrench in half and use the closed side and weld a socket on there so you can turn it with a ratcheting wrench. I don't know how to explain this better than that.
Old 11-25-2010, 07:33 PM   #10
PETERPOOP
PETERPOOP's Avatar
Done.
More pics to come after Turkey dinner.
Old 11-25-2010, 08:01 PM   #11
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Holy shit!
Old 11-25-2010, 09:20 PM   #12
Focus_Sh1ft
Looks great.
How'd you mount the intercooler?
Old 11-25-2010, 10:43 PM   #13
PETERPOOP
PETERPOOP's Avatar
For the AEM meth injection squirter/nozzle, a hole was needed to be drilled to fit it. We slightly bent the pipe so the nozzle could squirt towards the throttle body.
Oil catch can installed..
For the intercooler, it was mounted with some brackets we made for the bottom. Some plumber's tape was used for the top. It was kinda hard to make the intercooler centered, but we got it as close as we could.
Top shot..
Old 11-25-2010, 11:12 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
much better looking piping than the Greddy kit for the xA/xB
Old 11-26-2010, 12:06 AM   #15
Bluevitz-rs
^ for sure!!!
Looks awesome. I still can't figure out why the intercooler has an offset outlet? It looks weird.
Old 11-27-2010, 12:34 AM   #16
PETERPOOP
PETERPOOP's Avatar
Thanks guys. This a very short clip of the turbo flutter that happens when shifting. Taken with a junk camera. Expect MUCH MUCH better quality videos once I am tuned.
I am running 14.5 (lean) during WOT, so I haven't been driving the car around that much. It also drives at 15.0 during normal driving conditions (a little lean), and idles from lean to rich. Definitely needs a new tune right. Waiting for the AEM tru boost controller to show up before the tune happens. Mind you, this is running with my supercharger tune that I still currently have. Not sure what kind of AFR numbers you'll get, pretuned, if you didn't have management from the start.
http://www.youtube.com/watch?v=BWiamyiPFhQ
Old 11-27-2010, 01:34 AM   #17
Nexus1155
Drives: Audi
Anything outside of boost, 13.5-16.0 is acceptable, mostly it tries to stay stoich at 14.7.
You are also running a non recirculated BOV it seems, you can see the AFR gauge go rich when the BOV pshhhts.
Boost you should be at 11-12.
Hope you get someone to tune it good for you!
Old 11-27-2010, 01:13 PM   #18
PETERPOOP
PETERPOOP's Avatar
Just pulled out the old spark plugs, look kind of worn, and the gap is at about 1.2 ( that was with the S/C ). Planning on putting on new ones (NGK Iridiums), any suggestions on a good starting point for the gap?
I'm also running meth injection under boost, will that also affect the gap?
I'm going to have the tuner gap them during the tuning session, but I don't know when I'll be able to get the car tuned. But for now, I am going to put some new ones in.
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
