Old 02-06-2007, 12:28 AM   #1
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Originally Posted by Yaris TTE JWRC View Post
No, the crank pulley will not fit, the Yaris crank pulley one only holds one timing belt, Scion, Xa, Xb, and echo's crank pulley holds two timing belts, i know, because i have the Perrin Lighten Crank pulley on my Echo when i installed myself, and it is desgined for Sicon, as i look at my Yaris's crank pulley i could see it only holds one timing belt, so they are not the same , nice try buddy.
These engines don't have timing belts.
PetersRedYaris is offline   Reply With Quote
Old 02-06-2007, 02:19 AM   #2
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
Do you even know what a timing belt is?? how can an engine run without a timing belt, how are you going to run the water pump and powersteering?
Yaris TTE JWRC is offline   Reply With Quote
Old 02-06-2007, 03:03 PM   #3
PetersRedYaris
I do! Apparently you don't as eTimago had to explain it to you. Use the correct terms. It's a chain, NOT a belt, and is internal, as opposed to external with a plastic cover over it. People may interchange the terms accessory and timing when talking about belts but they are not even the same thing nor do they serve the same purpose. One reason I like this 1.5 liter motor is because it does NOT have a timing belt. That means no expensive timing belt replacement/service. You probably feel dumb now, I'll let it go.
P.S. We have nearly the exact same car, even the color is the same. We should be friends!
Tanabe Strut Tower Bar Install & Review [pics!] Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 57 04-07-2022 08:46 AM
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 07:43 PM
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) bigsky2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 01-10-2007 07:53 PM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM Performance Modifications 2 10-07-2006 03:26 AM
2006-2007 Yaris 4 Door Front Strut Bar AEM/DC Sport KenAEM General Yaris / Vitz Discussion 3 08-30-2006 10:43 PM
