Old 11-16-2010, 11:06 PM   #1
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
I'm a DIY'er and just starting my tool collection. Half the battle is having the right tool for the job, and obviously common sense. I much rather do this myself, know how to do it, your labour is free (except you have somewhere to be on a saturday afternoon).
Tools:
1. 3½-ton lift jack $150
2. 3½-ton axle stands $30
3. Impact wrench 300 ft-lbs (Milwaukee 9072-20) $200
4. Impact socket set $40
5. Torque wrench 250 ft-lbs $35
6. Wrenches $50 (go nuts on eBay)
7. Misc stuff like oil filter wrench, etc.. $50
Tools: $555
Supplies (lube and sealants, some of these you may not need given the job you tackle):
1. Oil 3.7 qts $15
2. Compressor oil (ND-OIL8) $8
3. Automatic Transaxle Fluid $5/1 qt. bottle (I believe)
4. Multi-purpose Grease (MP grease) 1lb $6
5. FIPG $20
6. Lithium Grease $3
7. High temperature grease (for brakes) $5
8. Coolant $14
9. Adhesive $5
10. Seal packing $25
11. Gasket maker $8
To get you started: $134
Common parts:
1. DIY Brake job ($200)
a. Drums $26/ea (vs. $78/ea dealer)
b. Hardware $10
c. Ceramic front pads (set of 4) $36 (vs. $39/set dealer semi-met)
d. Front rotors $40/ea (vs. $95/ea dealer)
e. Shoes (set of 4) $20 (vs. $36/set dealer)
2. Air filter $8 (vs. $16 dealer)
3. !GOOD! Oil filter $8 (vs. $4 cheap dealer filter)
4. S Belt $9 (vs. $26 dealer)
5. Wheel bearing (ABS) $50/ea (vs. $47/ea dealer)
6. PCV Valve $6 (dealer is $4)
7. Cabin air filter $7 (vs. $36 dealer)
8. Ignition coil (4 required) $65/ea (vs. $78/ea dealer)
9. Iridium spark plugs (4 required) $7/ea (vs. $11/ea dealer)
10. Front outer tie rods (2 required) $25/ea (vs. $46/ea dealer)
11. Control arm (w/ball joint) (2 required) $115/ea (vs. $233/ea dealer)
12. Rear shocks (2 required) $50/ea (vs. $37/ea dealer - not bad)
13. Front sway bar links (2 required) $35/ea (vs. $75/ea dealer)
14. Front struts (2 required) $55/ea (vs. $116/ea dealer)
15. Transmission filter $15 (vs. $66 dealer)
16. Wiper blades $5/ea (vs. $33 dealer)
For more technical folks:
1. Engine rebuild kit $450
2. Engine gasket set $150
3. Transmission rebuild kit $200
4. Clutch kit $150 (if required)
5. Axle replacement $150 (70 for each side) (vs. $400/ea dealer) (included this in technical side, because it's not always needed)
There could be more... like exhaust system, but this just gives you an idea...
salmonz is offline   Reply With Quote
Old 11-21-2010, 12:06 PM   #2
echaru
PsychMobile
echaru's Avatar
Drives: '10 Yaris 5Dr Blazing Blue
Tools:
Tools: $555
1. Oil 3.7 qts $15
5. FIPG $20
8. Coolant $14
9. Adhesive $5
11. Gasket maker $8
Common parts:
b. Hardware $10
Wow! With all the parts you listed, you should make DIY for all of them. I only know 10% of what to do with all those parts.
echaru is offline   Reply With Quote
Why does 15000 service cost so much more than 5000 and 10000 mile service? monyaris DIY / Maintenance / Service 7 06-25-2009 07:12 PM
5000 mile (8000 km) service due, what is to be done? kenora DIY / Maintenance / Service 3 06-25-2009 05:46 PM
10,000 mile service lindstothek DIY / Maintenance / Service 7 01-21-2009 01:42 PM
30,000 mile service: owners manual vs Dealer "recommendations" yaristotle General Yaris / Vitz Discussion 7 11-20-2008 10:41 AM
30,000 mile service: Dealership or non-dealership? EstherK DIY / Maintenance / Service 1 11-12-2008 12:40 PM
