Old 11-17-2010, 12:45 PM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
buy a 90 deg fitting and a flare a tube to go to the bottom of the pan. you do NOT want that hot oil hitting anything but oil when it enters the pan... if it comes out into just air, you'll foam your oil and do damage to your engine (much like overfilling will do)
Ok, so whose right about this? If you have oil hitting oil, then that means your line runs right into the oil, which is going to cause it to back up in the turbocharger. I now know this from experience unfortunately.
But now you're saying oil into air causes foaming? Uh...
Thanks for the pics btw.
Focus_Sh1ft is offline   Reply With Quote
Old 11-17-2010, 06:16 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
huh? you need to go pour soapy water into a pitcher and see what happens, then pour the same water through a hose into the same pitcher..
how would oil back up into the turbo because it terminates under the oil line? that doesn't even make sense..
Old 11-17-2010, 06:19 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
basic hydraulics will tell you to NEVER terminate any return line above the oil line. its not the oil hitting the air that causes foaming, it's the oil hitting the top of the oil. just like filling a bucket up that has soap in it. if you hold the hose above the water, the turbulence of the water landing on the top of the water will cause the soap to foam. if you put the hose under the water it does not disturb the oil..
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
