Old 11-17-2010, 01:37 PM   #1
Charles has his going into the Zage pan with no issues.
Old 11-17-2010, 02:57 PM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Hmm.. Is he using thicker than a -8 AN line? Also possible his banjo bolt has a smaller restricter I guess.
cdydjded, your return is setup just like PETERPOOP's at this point, right? No line on the inside of the block running down into the oil?
Originally Posted by cdydjded View Post
I look at it this way, if you looked at 1000 turbocharged cars Im sure 99% of them have the oil return above the oil line....
I'm inclined to agree. I can't see how hot oil hitting air would cause foaming. If that were the case, oil dripping down from the cylinder walls would foam, as well as the hot oil sitting in the pan...
Focus_Sh1ft is offline   Reply With Quote
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
