Old 11-17-2010, 10:12 PM   #1
YamilR
YamilR's Avatar
Drives: Absolutely Red Liftback
Send a message via Yahoo to YamilR
No oil pressure?
YamilR is offline   Reply With Quote
Old 11-17-2010, 11:07 PM   #2
Lil Abner
Drives: 2009 3dr LB Manual
Originally Posted by YamilR View Post
No oil pressure?
Yeah, I know my 2000 Celica had an oil pick-up screen in the bottom of the pan, fed into the pump, then through the engine. If that screen is clogged and you're not getting oil pressure, that could be your problem. Or the outlets are clogged. But you're making a HUGE mistake by driving it with an oil light on. With the noises you're hearing, I'm sure you've already done permanent damage to the engine. Hopefully someone can steer you in the right direction on this. If I remember right, the oil pan comes off pretty easy to check out the pick-up screen.
Tags
engine, low pressure, noise, oil, oil lamp
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
Transmission Oil for Yaris 1st Gen adigilani DIY / Maintenance / Service 3 10-23-2011 02:48 PM
My first noise bst82551 DIY / Maintenance / Service 9 08-13-2010 09:05 AM
1NZ-FE tuned by Phoenix-r sujonol78 Performance Modifications 50 02-08-2010 01:34 PM
Anyone running Royal Purple? firebird1999us DIY / Maintenance / Service 80 02-27-2009 10:30 PM
