Old 11-20-2010, 09:06 AM   #1
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by Midnight Drifter View Post
Size.............Offset Range.....Backspace Range.......Weight
14" x 6"........6 to 32mm........93.2 to 119.2mm .......13.6lbs
Based on that data, what would be the most preferred configuration for my wheels?
Depends on the size tyre you want to run, if you are dropped, and whether you want to make camber adjustments.
If you simply want to bolt some wheels on your car, then 14x6, ET32 would work with 175-185mm tyres.
Old 11-23-2010, 06:28 AM   #2
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Kinda trying to go wide here... if 205 can fit then 205 would be my preference. If not wider (somehow) Not looking to change camber, while grip is important daily drivability-even tire wear is twice so. Can I push 215? The more rubber, the better.
I think the wheels I'm looking at are lighter than stock steelies, but couldn't tell you for sure lol.
Midnight Drifter is offline   Reply With Quote
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 99 01-25-2026 12:51 PM
