Roadrunner Jr.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 12-13-2010 at 12:42 AM. |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
Never used that for sound deadening. What we refer to as a milkshake is bondo and resin mixed together.
#3 | |
![]() D. |
#4 | |
I'm going to start with Clay, inside the spheres and kick panels. For the A-pillars I'll use CLD Tiles with some Mat. Since my spheres are mechanically attach to the a pillars I'll isolate them with some Extruded Butyl Rope to prevent vibrations and try to reinforce the way the A-pillars attach mechanically to the chassis; because the speakers and deadening add a lot of weight to them. The Clay idea I'm not sure if it works or not, I read it online and makes sense but you guys are the PROS here, I just feel like the Clay can be removed if doesn't work, some other epoxy/glue/resin combination may be the best way to go, some times trial an error is my best friend. I think it can't be very rigid or stiff it should dampen the vibrations, be heavy and a little flexible to tolerate changes in temperature. Well, that's what I think, if there is a better way to approach it, let me know I don't want to re-invent (H2O) D.
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| ))) Tein Super Compact coilover install tips ((( | aucorium | DIY / Maintenance / Service | 4 | 10-25-2011 12:42 AM |
| Micro Image underpanel install DIY | cali yaris | DIY / Maintenance / Service | 27 | 08-29-2009 09:48 PM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| where can i install these power locks? | songa | New England | 1 | 12-04-2008 12:41 PM |
