Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 11-30-2010, 06:28 AM   #1
markylicious
markylicious's Avatar
Drives: 2010 Yaris Sedan "Abyss"
Originally Posted by xtremist View Post
pre, mahal nga kng sa paintshop kc buo nila pipinturahan, kng d nman gaano kita, leave it nlng muna sa touch up paint, try mo nman post pic ng makita ng ibang kayaris, baka makapag suggest din cla.
cge.. kunan ko pic tapos post ko agad d2 bukas.. plano ko bumili ng maliit na brush para gamitin instead if toothpick
markylicious is offline   Reply With Quote
Old 12-01-2010, 02:18 AM   #2
markylicious
nailagay ko na sa albums ko ung pics ng gas2x... http://www.yarisworld.com/forums/album.php?albumid=574
Old 12-01-2010, 03:35 AM   #3
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Bro saw d pix, medyo malalim nga ito at mahaba. If ever man makuha sa touch paint, halata mo pa rin. Your call bro...
jonimac is offline   Reply With Quote
Old 12-01-2010, 07:47 AM   #4
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
malalim pla pre, akala ko babaw lng, mukhang d kakayanin ng touch up paint to, kc pra lang un sa small scratches ska chipping by small stone. mukhang kailangan mo tlga ipasok sa shop pero make sure maayos n shop, otherwise magsisisi k kc minsan walang kintab ung kulay nila, try mo hnap nung may automatic mixer, input lng nila ung paint code mo den bhala n ung machnie magtimpla (un ang sabi skin nung napagtanungan ko pinoy pintor d2), ipapaayos k din kc ung skin eh.
by the way pre, ung hood ng auto ko iba ang kulay kc libre lng nung pinunturahan after batuhin yun nung nainggit na arabo, kya ipapadamay k din repaint sbay ng bumper ko.
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 11-30-2010, 07:54 AM   #5
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
www.paintscratch.com
ricepower is offline   Reply With Quote
Old 11-30-2010, 08:00 AM   #6
markylicious
If you get paint on your skin, remove with paint thinner and wash thoroughly with soap and water.
Do not try to use the paint pen on areas larger than a pencil eraser. Larger areas must be sprayed.
Paint can easily leak out of the paint pen if you do not use it correctly!
Do not try to brush areas larger than a dime. Larger areas must be sprayed.
Use an approved automotive paint respirator and WEAR safety goggles and gloves when handling automotive paint to protect your eyes and skin!! Please read the information below for best results.
When spraying, always test for paint compatibility. Paint an inconspicuous part of the vehicle, let dry and see if there is any reaction.
Do not spray our paint over enamel paint that is less than two years old.
Do not spray primer, paint or clearcoat in direct sunlight!
First time? Did you know you can completely remove any new paint with automotive lacquer thinner and start over without damaging the original finish?
Make sure you use SEM Adhesion Promoter if you are spraying a non-metal surface. Failure to do so will result in the paint peeling off within a few months!
Old 12-01-2010, 11:29 PM   #7
markylicious
mga sir nag pa estimate ako kung magkano magagastos sa kanila kagabi d2 sa may umal-hamam. sabi ng pinoy 350 daw.. e ooven daw dila.. bumaon daw kasi ung may gas2x. ok nba ung 350?
Old 12-02-2010, 12:31 AM   #8
xtremist
xtremist's Avatar
blessed, pki check ung quote ky marky, ok b ung 350 pra dun sa damage nya? for me marky try to negotiate more kng papayag pa, pwede cguro 300 kc mostly 300 ang kada parts (pinto, bumper at iba pa) as per dun sa napagtanungan ko...kng oven pa, maganda cguro finish nun. mga kyaris, wat do u tink?
Ciao !!!
Old 12-02-2010, 12:31 AM   #9
xtremist
xtremist's Avatar
pre, dun sa katabing pinto (front passenger side) prang may tama din na maliit...
Ciao !!!
Old 12-02-2010, 12:45 AM   #10
markylicious
oo e ooven daw nila sir.. nag tanong2x din ako sa tapat na shops nila eh nasa 500-800 ung singil..
ung maliit na tama sa kabilang door pwede lagyan ng touch up paint.. maliit lang nmn ung gas2x at d malalim.
mga 10am today ako pupunta dun sa shop para maumpisahan na nila.
Old 12-02-2010, 01:12 AM   #11
xtremist
xtremist's Avatar
goodluck bro, db bago lng yang auto mo?
Ciao !!!
Old 12-02-2010, 01:30 AM   #12
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
mark mahal naman ata nun, try ko muna kontakin ung iba, pending mo muna yan
syntax is offline   Reply With Quote
Old 12-02-2010, 01:11 AM   #13
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@Marky, gano daw katagal? Kasama na ba lahat dun pati paint job?
rye7jen is offline   Reply With Quote
Old 12-02-2010, 01:19 AM   #14
markylicious
oo lahat na pati paint job.. isang araw lang.. pwede ko na daw balikan mmyang gabi
Old 12-02-2010, 01:41 AM   #15
markylicious
cge paul.. tawagan mo ako ha. hintayin kita. ty
Old 12-02-2010, 02:26 AM   #16
syntax
syntax's Avatar
paul ?
Old 12-02-2010, 02:46 AM   #17
xtremist
xtremist's Avatar
Originally Posted by syntax View Post
paul ?
wahahaha...wow at ganda nman ng name nya...d na shadowpao....hahahaha
Ciao !!!
Old 12-02-2010, 02:53 AM   #18
syntax
syntax's Avatar
ok na ung shadowpao eh sabay banat ng "paul" meron na may ari ng name na paul sa forum na ito, baka naman sabihin nang aagaw ako wahahahaha
