Im glad i caught it early, tho i cant know for sure i did catch it early, it is most likely started with the pothole on friday.
Any tips for repairs? I know how a PITA it is to just install the boot...labor intensive
#2 | |
There are aftermarket "repair" boots that glue together and don't require pulling the axle to install, but I've heard mixed reviews on the longevity of them. I would pull the axle, completely degrease the joint (to remove any contaminants that got in with the ripped boot), re-grease, and replace the boot. Pulling an axle is not that bad, other than breaking the axle nut loose. You need a 30mm socket for the axle nut and a tool to "un-dent" the axle nut to allow it be rotated. It has a dent that acts as a locking mechanism. |
| DIY LED Strip under the door panel | charleschia1986 | DIY / Maintenance / Service | 19 | 11-05-2011 07:49 PM |
| Interior LED Ricey Problem | xbr3akd0wnx | Cosmetic Modifications (Exterior/Interior) | 10 | 05-06-2010 08:50 PM |
