That's the rattling of the shift cable. If you look at the TSB list in the DIY section, there's a TSB on it that basically involves using a cable tie to keep it from rattling.
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Nov 2010
Ok, thanks... that makes sense because it does sound kind of like a rattle. Would it also be doing the same thing in drive? I only ask because the TSB and googled complaints only state it's in reverse and mine is doing the same in drive and reverse, even though the sound is slightly louder in reverse.
And at the risk of sounding like a moron... Do you know of any picture or diagram of where I should look for the cable? I really want to avoid the dealer and know I could do this myself if I knew where to look. Thanks again. |
Here's a picture of the culprit. The TSB has the tech cable tie the AT cable to the wire bracket. That keeps it from vibrating against the bracket or the exhaust shield. I believe that it does it in both forward and reverse, but in reverse the cable has more slack so it vibrates more.
AT cable and bracket: AT Cable.jpg It is most easily accessed from above. It is directly below where the heater core lines enter the firewall, to the left of the brake booster. In this pic, if you looked straight down from the center you'd be looking right at it. AT Cable Location above.jpg |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
Interesting.. Does this only apply to manuals? I have the same type of noise as of recently, but so far I've attributed it to the multiple tools I've dropped into the engine bay.
| Tags |
| engine, idle, noise, tap, tapping |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| FS: Used Beatrush Engine Roll Stopper | FunctionSpec | Items for Sale by private party | 7 | 06-02-2010 01:38 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
